Power Steering Problem
I ahve A 67 chevy 1/2 ton truck that had manual steering. I took a pwr steering box off a 71 chevy to convert mine to pwr steering. when I tried to mount it the box was hitting the frame in between the mounting holes, so its not mounting flush. has anyone had this problem? and if you know how to fix it? id put spacers in it but i dont know if that would be safe. any help is appreciated. thanks!
Re: Power Steering Problem
you might search around on here some it may even be in the FAQ section but yes the frame is different for power streering vs manual. Most people I believe will heat and dimple the area where the box goes to make it fit in the frame. I have not done this but remember reading about it.
Good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Check out Classic Performance Products tech articles.
Restoration Desperation
You should only have to notch the bumper bracket. That is what kept the steering box from moving forward enought to line up on my '68. I just removed the bumper bolt at the frame & it is still hanging there waiting for me to grind the notch & re-bolt.
RD |
Hellasick
![]() Join Date: Jul 2006
check this thread out...might be some help. know there are better pics somewhere, but cant find them yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=255352 found another thread http://67-72chevytrucks.com/vboard/s...d.php?t=192229
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 08-21-2008 at 09:38 PM. |
thanks for the info everyones giving me. Does anyone who has spaced there box out if they know about how much of a space and where I can get spacers to do it. thanks again.
