cannot get hood to line up between fenders
how can i get the hood to set straight in the fenders at the cowl. my hood is dragging on the drivers fender with a big gap on the passenger side. any help would greatly be appreciated, thanks fellow members of the forum.
Resident of Here
Re: cannot ge hood to line up between fenders
Adjust it on the hinges, You need another person to do it. Loosen the bolts then slide the passenger side closer to the cab. etc. etc.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
I got this tip from a fellow board member when trying to adjust my hood. With a person on one side of the vehicle and someone else on the opposite side of the vehicle, on the count of three, one pulls and the other pushes the hood toward the side that has the largest gap. This will allow the hinges to "spring" in that direction. It worked for me. It took a couple of tries, but it worked.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Mine was like that and I put shims between the hinge on the driver side. Still not perfect but its a lot closer.
69 Chevy 4x4 383 Power ![]() |
is that with the hood closed or open when you sprung the hinges?
That is with the hood about half open.
Farm Truck
![]() Join Date: Aug 2006
Did You Put The Shims That Go On The Top Two Fender Bolts?
THE HINGES MOVE BACK AND FORTH ALSO
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx Last edited by Stoney; 08-19-2008 at 10:33 PM. |
Re: cannot get hood to line up between fenders
uhhh, what shims, maybe that is my problem?
Farm Truck
They Look Like Front End Alignment Shims
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
got one on the pass. side fender, moved it to drivers to pull it away from the hood. didnt work.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
How far has your truck been taken apart? There could be a host of problems that could be giving you trouble.
1.) Is your cab square on the chassis? 2.) Are your hinges worn out? 3.) are the front fenders and core support square to the cab? You might try loosening the core support bushings and pushing the front fenders and core support toward the driver's side. If your hinges are worn out then you will fight them untill the cows come home and still not get it right. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#12 | |
Mike |
Did not realize that you are in Houston. Bring it by the shop and (THe other MIke ) our body shop manager can show you how to line it up.
There is generally someone here around 8am to 8 pm most all days Last edited by mbgmike; 08-20-2008 at 07:17 PM. Reason: added |
