Old 08-20-2008, 09:44 PM   #1
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Im looking at a 72 GMC
It is for sale for $700 and its a 2500 and was wondering should I get it or not. What did those 2500s come with stock??? It has a dark blue paint and it has cab corners and their is the front part of the bed I could use mine is rusty and holy. Just want info on it and Im not selling it.
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 08-20-2008, 10:10 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Im looking at a 72 GMC
I am confused about the cab corner part. You don't want to cut off used corners and put them on your cab do you? New cab corners are very cheap.
Almost everything was an option on any truck, nothing was "stock".
what are your plans for it? $700 is alot of money if all you are wanting to do is cut out a few bed parts.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-20-2008, 10:32 PM   #3
70' GMC
70' GMC's Avatar
Im mean the truck is in good shape no rust on the exterior I will look at it and get pics. Longhorn Man do you think it may have a dana rear end or even a diesel engine? Or Im way way way off from it?
Old 08-20-2008, 10:21 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
travis, all the body panels will match up with your 1/2 ton. The grill is not the same, but it would bolt right up if you determined you liked it better. The frame, for the best part, is pretty much the same too. A little bit of added bracing, and some stronger springs, that's about it. The suspention is not the same as your 1500, you shoulda figured that one out already. So from the springs on down, you won't use the parts. However, pretty much everything from the frame up, can be used on your 1500.
Stock, as in no options, it would be equipped the same as a 1500... a CE model would have a 307/3 sopeed on the column and 4.57 gears, a CS model would be a 250 inline with a 3 on the column and 4.57 gears.All the engine and tranny options are the same as the lighter duty counter part, the gearing is a lot lower, but again, that rear isn't what you'd want anyways.
Old 08-20-2008, 10:31 PM   #5
ksjh1316
ksjh1316's Avatar
Travis
Go look at it it may have all the panels to make yours solid again. If you are looking for advise on it get us detailed pics and make sure to see if the SPID info is still in the glove box.
ksjh1316 is offline   Reply With Quote
Old 08-20-2008, 11:09 PM   #6
Longhorn Man
it might have a dana... but if it is an inline or small block, odds are it's the eaton. (Why would you want a 3/4 ton dana?)
Diesel??? very very VERY unlikely.
Old 08-21-2008, 01:10 PM   #7
70' GMC
70' GMC's Avatar
what is an eaton is it a part of GM?????
Old 08-21-2008, 01:42 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Does it run? It sounds nice enough to drive.....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-20-2008, 11:20 PM   #9
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Originally Posted by 70' GMC View Post
Im not selling it.
WHAT? C'mon, I'll drive there and get it from ya for 701$
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-21-2008, 02:25 PM   #10
Riveted1
Tasty Cakes!
Riveted1's Avatar
Uhhh... First post on this thread... remember that? Hehe... J/P w/ya man.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-21-2008, 03:04 PM   #11
70' GMC
70' GMC's Avatar
Ill tell ya its located in hallsboro NC and the woman knows one of my uncles very well.
Old 08-21-2008, 06:22 AM   #12
Look to see if it`s got leaf springs.Your 70`has leafs,right?
Old 08-21-2008, 02:38 PM   #13
Longhorn Man
the eaton is pretty much slang on these boards.
The correct term would be corperate rear axle, with an eaton differental.
GM made the body of the rear, and eaton made the guts.
Eaton is still in buisness making trannys and rears for med and heavy duty trucks. Very good rears in the old trucks like ours, but the parts are getting hard to find for them (72 was the last time that model rear was used).
Old 08-21-2008, 03:02 PM   #14
70' GMC
70' GMC's Avatar
so its worth 700 bucks easily I did take a quick peek at the interior and their is barely a steering wheel all I seen was metal. The seats looked pretty darn good so was the interior but no tailgate. Other than no tailgate it still looks good.
Old 08-21-2008, 03:17 PM   #15
Longhorn Man
it's hard to say if it is worth 7 bills from your description... esp as a parts truck, which I am assuming is why you want it.
Now, a s a work truck... if it runs and drives, it's worth the cash. Even just as a driver/beater, it's probably worth 7 bills. But, if it is a parts truck, you need to figure out what you need, see if it has those parts in good shape, figure what the value of those parts are, then what you'll do with the carcass of the parts truck... it can be a real pain in the 12 bolt.
Old 08-23-2008, 01:04 PM   #16
70' GMC
70' GMC's Avatar
I need to look at it again I havent had the time lately to do anything
Old 08-23-2008, 02:22 PM   #17
ksjh1316
ksjh1316's Avatar
Thought this would have been said by now. Come on Travis you have all weekend get us some pics and we can give you more info
Old 08-23-2008, 09:02 PM   #18
tcb-1
Nothing to see here.....
tcb-1's Avatar
Travis, try to take some good photos and post them. (not with your phone cam, either!) That way, everyone can give you thoughts on whether it's worth $700. Look to see if the spid is still there on the glove box door as well.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-25-2008, 11:02 AM   #19
70' GMC
70' GMC's Avatar
Last night I was told 200 is what its worth and 300 if I really want it. She cant even get 700 dollars for it for scrap. Its a guy that knows a whole bunch about scrap and the prices
