08-22-2008, 11:22 AM | #1 |
79 c10 parts on 67 c10
anyone what mods needs to be done to put 79 c10 pwr disc brakes and pwr strg (if any) on 67 c10
08-22-2008, 12:23 PM | #2 |
Re: 79 c10 parts on 67 c10
You need to either switch to ball joints for the 79 or just bolt the 79s upper and lower control arms on your 67.For the steering the frame needs a small dip in it where the box bolts up to keep it from hitting the frame.68 and up have this already there but 67s dont.Just mark where it hits and take a torch and heat it up and "massage"it with a hammer.You could shim it with some washers but I dont like that method as much.You can also use the booster and master but the rod needs modified.
08-22-2008, 01:12 PM | #3 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
