08-22-2008, 11:20 PM | #1 |
I have an idea, need input
Just would like everyone's thoughts on this custom idea I have.
My 69 has some pretty good bed rust in the rear. I was thinkinf about a bed patch panel, but got to thinking, what about a wood bed? Is it even possible? Do you see potential problems. I thought it would be perfect for going topless, and would be way original. Eric
!969 K-5 Blazer 1973 Pontiac Grand Am 2004 Chevrolet Avalanche 2004 Jeep Wrangler |
08-22-2008, 11:25 PM | #2 |
I'm a poor spectator
Re: I have an idea, need input
Look at the last few pages of Jaros44's build up, there are some pics of one with it, looks really sharp too.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
08-23-2008, 06:31 AM | #3 |
It's a great idea that looks killer.
Jim's thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=210641 Pic of the floor found on page 6 - Last edited by vtblazer; 08-23-2008 at 06:32 AM. |
08-23-2008, 08:11 AM | #4 |
The LuvShack Garage
If I was keeping "Merlot" (Which I am not) I was going with this idea,
however I was going with a drop in show deck. There is a guy in KY? I think that makes these drop in kits. (Remove when ya want to haul or know it's possibly gonna get wet) Down side was he around $700?
08-23-2008, 08:37 AM | #5 |
Can't wait to retire!!
I think it's a great idea as well. I wish I would've thought of doing it myself. Jaros44 did a great job on his.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
08-23-2008, 09:10 AM | #6 |
Hey Guys thanks for the props, here are some more
08-23-2008, 09:17 AM | #7 |
Looks nice, easy solution to a rusted floor but I think there is a pretty good reason they didn't come like that from the factory.
Unlike the bed on a pickup which is basically just an open box sitting on a frame, the steel floor on a Blazer is an integral part of the body. The original metal floor has mounting points that the rocker boxes attach to. This is what basically keeps the body from bending in half at the doors. If you were never planning on taking your top off again then I could see it might be a possibilty but the way that the bed floor is such an integral part in keeping the body from flexing, IMO without some pretty tricky framework underneath there is no way strips of wood could replace the strength of a solid piece of steel. |
08-23-2008, 09:22 AM | #8 |
All of the original crossmembers are under it, and it does tie into the torsion/rocker boxes....but I suppose you could argue that a 3/4" pc. of oak is not as strong as a 1/16" pc. of steel.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-23-2008 at 09:24 AM. |
08-23-2008, 10:05 AM | #9 | |
08-23-2008, 10:24 AM | #10 |
Thanks for the input. The structural integrity was an issue to me also, I thought the supports underneath provided most of it. I know with the top off and tailgate down the bedsides aren't that stable anyway. I'm sure a few mods here and there could shore it all up.
Jaro, it looks fantastic! What are you using for front and rear trim on the wood?
08-23-2008, 10:30 AM | #11 | |
BTW, thanks
08-23-2008, 12:20 PM | #12 |
I have a radical idea!
I have been kicking the idea of a wood floor like that with custom wood door panels stained the same color like Frizzle Fry's in my Blazer. It would almost have a woody look on the inside!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-23-2008, 01:30 PM | #13 | |
Yes the kick panel area holds the front windsheild frame in position. I guess my point was the area where the cab floor meets the bed floor. What happens if you take the top off a Blazer that has the rocker boxes rusted out? The body isnt so much tied to the frame as it is sitting on it. My main area of concern in tieing the rocker boxes into the floor is the rear most cross piece on the bed that the end cap attaches to. That cross piece is spot welded to the bed floor and not sitting on mounts. I guess all these thoughts stem from having seperated the front half from the bed floor on a Blazer, I realized how much stress the rocker box end caps are under once they are bolted in. One more thought I had was what about the extra thickness of the wood compared to the steel when the bedsides are on it? Wouldn't that raise the bedsides up higher then where they should be? |
08-23-2008, 09:37 PM | #14 | |
You shouldn't be running around with rusted out torsion boxes, or you will be asking for flex problems
08-25-2008, 05:16 PM | #15 |
Old School, New Style
It's been done a few times on here. Do a search.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
