Old 08-24-2008, 11:33 AM   #1
andresco50
andresco50's Avatar
Help me guys...
I installed a new regulator in the window, everything is right but when I installed the door interior the handle looks terrible check the pics!! and give me some ideas to fix it please
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 08-24-2008, 12:05 PM   #2
vern350
like a rock
vern350's Avatar
Re: Help me guys...
did the 1.5-2 inch black sponge like spacer go back in between the door and panel on the window crank?
vern350 is offline   Reply With Quote
Old 08-24-2008, 12:41 PM   #3
cochino12
It followed me home?
cochino12's Avatar
Re: Help me guys...
I could be wrong (I probably am ha) but arent the internals and other door stuff different from 73-75? What year did you pull the regulator from? I assume by your sig your truck is 75?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-24-2008, 12:54 PM   #4
ca180
tryin to get laid
Re: Help me guys...
Probably a change in year, I'm not positive, but it could be.
On my 72 f-100 I put some window cranks from a newer models cause mine were beat and they had a gap about like that. Of course that is a ford though. Perhaps you could just pick up a set of handles from your local yard. Shouldn't cost you a buck for both.
ca180 is offline   Reply With Quote
Old 08-24-2008, 02:33 PM   #5
gafiredog
Re: Help me guys...
i think the 81-87s are longer due to the different door panels, may be wrong though.
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 08-24-2008, 02:50 PM   #6
Jimbob91
Re: Help me guys...
GAfiredog is correct. Measure the shafts of the one you pulled out and the one you put in.....I'll bet the new one's longer.
Matt
91 GMC K-5 Jimmy 350/700R4/241/10boltX2 W/4:56's/locked. 6inch Softride on 35's. Starting to show signs of trail life...
86 Chev K-10 Short 383/350/208/10&12bolt Gonna be the pretty truck...
Jimbob91 is offline   Reply With Quote
Old 08-24-2008, 04:56 PM   #7
andresco50
andresco50's Avatar
Re: Help me guys...
Yes maybe I bought it wrong the 74-76 is different i bought a 78 maybe
2001 silverado 2wd
2003 silverado 4wd
Old 08-25-2008, 12:34 AM   #8
f.monroe
f.monroe's Avatar
Re: Help me guys...
The length of the window crank arm was lengthened in 1977 when the door panels changed . If you use the 77 up regulator in a pre 77 truck , it will look like that .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 08-24-2008, 02:50 PM   #9
ca180
tryin to get laid
Re: Help me guys...
Hmmm, I need to rethink my post. I think gafiredog is right. So putting new handles on won't make it any better. You are pretty much left with replacing the regulators completely. Hopefully someone who has run into this will chime in.
Old 08-25-2008, 11:28 AM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Help me guys...
Ditto on what Frank said. You have 77-91 regulators in a 73-76 door. There is no "fix" to it other than getting the correct regulator.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-25-2008, 05:42 PM   #11
andresco50
andresco50's Avatar
Re: Help me guys...
I can cut and weld the window crank arm !!
2001 silverado 2wd
2003 silverado 4wd
