Schlongbed MEMBER (heh)#15
What is the 2nd linkage on my AT?
I'm not going to pretend like I know, I just know it's there. I can select gears just fine. but there's this 2nd linkage.
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
Re: What is the 2nd linkage on my AT?
Perhaps this second linkage connected to the steering wheel lock ? I don't really know either !
If you have a powerglide or TH-350, it's the passing gear/kickdown for when you stomp on it. It doesn't need to be hooked up on these transmissions, but you'll probably have to downshift manually when you want to pass. It hooks to the carburetor opposite where the throttle linkage connects.
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
#4 | |
I dont think the tranny will work right if its not there and properly adjusted. |
hmmm. It's on the driver's side of the transmission same as the throttle linkage. I remember having to set the kickdown in the past.. hmmm
1962 C-10
It will work okay, it just won't kick down. Th350's don't need the detent cable like 200's and 700's do.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
I wanted to be sure. The damn tranny slips in between shifts and I didn't know if that was a culprit.
I'll be honest and say I know jack about Auto Transmissions.
I bought a fresh rebuilt th350 once and the detent cable was not set right and the tranny slipped. Took it to the place I got the trans from and 5mins later after the adjustment it didnt slip and shifted fine. Yes it was a 350 trans. I thought there was a pressure regulator that runs off the detent cable too???
60-66 Nut
If you have either a 200R4 or 700R4, the cable is called a TV cable, or throttle valve cable. This cable controls the pressure in the trans and if it is not adjusted properly you can burn up your trans. I think we need to determine which trans you have.....
1962 C-10
I agree...
#11 | |
283 Drama Queen
![]() Join Date: Dec 2004
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
283 Drama Queen
Stopped by HB Trans yesterday on the way home from work - "not good" was what the owner said - she goes in Monday for a review and if everything's okay, a reconnection of the kick-down and adjustment.
Wish me luck - this could get ugly quick for the Chevelle. ![]()
it's a 2 spd if that helps. I've been doing other stuff.
KOFFIN DRAGGER
powerglide... my linkage is missing and mine works fine with out it, just have to yank the shifter to get to passing gear, but with a 6 banger and low gears, I aint doing much passing
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
#15 |
So it is in fact the detent cable for my tranny which is a Powerglide. Now I just gotta find one.
#16 |
283 Drama Queen
The Blue Lives! It cost $255.00, and two days, but I don't care! Hardware came from Classic Industries - 300 feet from my guy at HB Transmission, and it shifts and 'kicks-down' perfectly. Now it shifts at about 30-35 mph instead of 15-20 mph and delays shifting as long as I like it if I mash the throttle from the light!
