08-27-2008, 03:51 PM | #1 |
Motor Mount Opinion
I'm in the process of building a 355 for my two wheel drive blazer that will be 350+ HP. It will mainly get driven on the street, and I'll beat on it, but I may also run it at the track from time to time.
I've heard that the stock motor mounts aren't that strong. Is this true? Is it worth switching to '73 and up clamshell mounts or aftermarket ones like performanceonline.com sells? I would like to put this motor in right the first time but don't want to spend unnecessary money. Any opinions?
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina Last edited by k5hart; 08-27-2008 at 03:51 PM. |
08-27-2008, 03:54 PM | #2 |
Re: Motor Mount opinion
im still using the factory style mounts in my 71.. i race it often at the track and abuse it on the street. i also plan on a 200hp NX kit later so i guess ill test them out then too.
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
08-27-2008, 04:10 PM | #3 |
put a torque strap on the engine drivers side to limit excess movement and you'll be just fine with stock mounts
08-27-2008, 07:59 PM | #4 |
Excellent idea. I didn't even think of that route. Cheap and simple. Thanks for the answers guys.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
08-27-2008, 09:22 PM | #5 |
Never had a problem with mine...I don't race but I tow a trailer loaded down with lumber regularly.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
08-28-2008, 08:16 AM | #6 |
Do the later clam shells bolt right in?
08-28-2008, 08:21 AM | #7 |
i think you need new towers for them to be a bolt in piece, or modify your stock towers. also i think if you use the stock towers without modifications the motor will sit higher.
08-28-2008, 02:20 PM | #8 |
I heard the same thing about the engine sitting higher. I think I'm sticking with my stockers until it gives me a reason to change. Thanks for the input everyone.
