aftermarket bigger brakes
I drive my truck daily and there are some crazy drivers around the DC/Baltimore area, i was playing around with the idea to possibly upgrade the front brakes (i have front power disc's in my 71), such as mutiple piston calipers and bigger rotors/ drilled or slotted rotors. i know that some of these big kits you cant run 15 in rims, i would like to keep my 15's just so i dont have to buy all new wheels. any of you guys out there running beefed up brakes with 15's? if some pics and info would be much appreciated.
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
Re: aftermarket bigger brakes
SSBC has a kit that allows you to upgrade the rotors and the calipers while retaining 15s, I think thye are the only one. I have them and love them.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
man if you had any pics i would love to see them, i was just on their website, but it didnt look like they had any stuff for our year trucks. are yours the force 10 2, 3, or 4 piston's? and can you feel a noticlbe differnce between them and OE. also do you have special rotors? thanks.
![]() Join Date: Jul 2007
There are also several outfits making kits to convert the rear drums to disk.
It is a popular conversion with the rock crawlers. One might have to mix and match parts on a two wheel drive though but I think front rotors for a 77 Eldorado could fit if the center hole can be made to match the rear hub on the truck. |
I don't know what size tires you're running or what your truck weighs, but I've got 4 wheel disks, I think they are 12 inch rotors and the thing stops so fast you can lose your gum.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 08-28-2008 at 11:35 AM. |
its a lwb fleetside, with average size tires, cant remember the size, someone told me once that rear disks on these trucks didnt make much difference over the stock drums, what do you guys think? maybe that guy was wrong, i have no clue
I don't know if the rear disks make a difference or not as I never drove it with rear drums. I have drilled front rotors with 275's tires in front, the rear are 285's and the gas tank is back there also, so I have a bit more weight over the rear combined with a lot of rubber on the road which I'm sure really helps quite a bit.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
![]() Join Date: Apr 2008
You could upgrade to a two piston setup and add drilled/slotted rotors and some performance pads.I have gotten a better pedal feel with braided hoses over the rubber but I cant tell you if it stops better from them.
When upgrading your front rotors keep in mind the original stock rotors were 11.8" (3/4 ton 8 lug has 12.5" rotors). That is darn near 12" I don't know if the money is really worth upgrading to 12" in front. Bleed the brake lines and use DOT 4 or 5 synthetic Brake fluid. I am a believer in Stainless braided or Kevlar lines, high quality brake pads (I like EBC), and Dimpled and slotted rotors. Many manufacturers have left the drilled rotors (holes all the way through) due to cracking at the holes. Dimpled gives you the same look, but not the problems of cracking. These things will help out tremendously without blowing a budget.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 08-28-2008 at 02:21 PM. |
Yeah, the stock size rotor isn't too much of a problem.
I know summit sells some 2 piston calipers that will fit our trucks (can't remember the brand off the top of my head), as well as good brake pads (another nod for ebc), stainless steel hoses. I've also heard good braking improvements using a 3/4ton brake booster. I would imagine that if you do all that, your truck will be stopping good. I'm going to go with bigger brakes on the front of mine, but that is primarily to fill up the 20s ![]() |
I also agree with a dual diaphragm brake booster normally found on the 3/4 ton trucks.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
yeah i had heard that about the 3/4 booster, i will do that in the future, i also plan on installing an adjustable prop valve in addition to the factory style prop valve, so i can fine tune the front/back sensitivity, right now my back are locking up before the fronts, i have a brand new prop valve that i havent installed yet. do those slotted/drilled rotors really help with brakeing? i have heard that they are mainly to minimize warping and heat buildup. good point about the rubber lines guys, i will put that on the list to get as well.
The slots actually help with the off gassing that occurs when the pads are heated up from hard braking. The gas can form a thin cushion between the pad and the rotor causing the braking action to be compromised. You shouldn't need an adjustable prop valve with a good working original style prop valve.
You could also switch to a hydroboost,the have lots of brake pressure.
#15 | |
silly slotted rotors or dual pot calipers aren't going to help you much, if at all. you are looking for more clamping force... not better heat dissipation. if you experience brake FADE, (the only reason to switch to drilled-slotted-and ceramic pads) then you are driving like a whack job anyway, and you're not going to take anybody's advice. If you've never lit a brake pad on fire while braking, then you don't need any of this stuff to increase clamping force, run a better vac booster, or run hydroboost. hydroboost systems from late model GM pickups can be had for less than $100 on eBay, and will lock all four if you really want to. Bolt-in + routing some hoses from your PS pump -> hydroboost -> back to PS resovior and to PS box. easy as pie. I think I'll do a write up on the install tomorrow evening, as I'm upgrading to a GM P-30 hydroboost big brakes, drilled & slotted, dual piston, fancy pads... all for racing. take it from a SCCA racer.
RN U OVR Last edited by Senator350; 08-28-2008 at 08:12 PM. |
#16 | |
![]() Shawn
