brakes ? again
i'm beating the dead horse.
could some one make me a list of what i would need to swap to disc on the front. 1. will 86 A arms and components work? 2. upper arms 3. lower arms 4. spindles 5. rotors 6. calipers 7. inner tie rod ends 8. outer tie rod ends 9. master cylinder w/ power booster 10. brake lines. did i forget anything? idler arms pitman what else is down there? i need an exploded view of the components |
Re: brakes ? again
1) Prop Valve
2) Tie-Rod end adapters (to match inners with outers from different years) |
Re: brakes ? again
where do you get tie rod end adapters?
