Old 08-29-2008, 01:34 PM   #1
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
coupler/rag joint??
I have two questions about this coupler/rag joint.
1. What is that wire in the center for? I see it connects a bolt and a pin, but why?
2. Are there two different size couplers for the 2wd, w/ power steering?
I am putting a 69 tilt in a 71 that had manual and I switched it over to power long ago. I used a gear box from a junk yard truck. I don't know what year it was, but it was a 67 -72.. I have two different sizes????
Maybe I can clean it up tomorrow so I can get a better pic....
LOW DOUGH is offline   Reply With Quote
Old 08-29-2008, 02:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: coupler/rag joint??
I would guess it is a ground for the steering column shaft for the horn.
LockDoc
Leon
Old 08-29-2008, 02:49 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Yes, ground strap.
sneakysnake is offline   Reply With Quote
Old 08-29-2008, 02:56 PM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Makes sense....
What about the 2 different size couplers?????
Old 08-29-2008, 08:41 PM   #5
pickupman
pickupman's Avatar
Manual and Power is different, 2wd and 4wd are the same
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 09-02-2008, 09:30 AM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Hmmmmmm,
The truck was a manual. I put power on it. The tilt column came from a P/S truck. The gearbox I put on when I converted a long time ago was from a 2wd.
I just don't know which one to order. I will have to get more/better pics to try and explain what I have/done.
Everyone’s help is very much appreciated.
Old 09-02-2008, 09:35 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Devil's Advocate here....
If you have two rag joints, with one that fits the column and one that fits the steering gear box, what is the possiblility that you can take the two, and make one that will do what you need to do? The joint attaches to the flange on the gearbox. The studs hold the flange on the column. Is it doable?
Member Nr. 2770
Old 09-02-2008, 09:40 AM   #8
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
True. But the bolts are messed up on the one i need. I was also trying to replace the rag joint (rubber part) in it. How do you take the da** thing apart? How do yo uget the "cap studs" or what ever they are called off? I am stumped unless I just cut them off????? I don't know.
How do you take it apart?
Old 09-02-2008, 10:26 AM   #9
sneakysnake
Pull the bolts to separate the rag joint. Order the one for the type gearbox you have.IIRC,Manuals had a closer bolt pattern then the power.
Old 09-02-2008, 11:03 AM   #10
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
What about the 2 that are not bolts? well, they don't look like bolts. How do they come apart? On the right and left of this pic.
Old 09-02-2008, 11:42 AM   #11
sneakysnake
If yours is a rivit then the whole thing can be replaced, or some kits let you grind them off and give you ones with nuts on the back
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=137
Old 09-02-2008, 11:55 AM   #12
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Yeah, I was thinking I would have to grind them off. I don't want to pay $50 for a new one. I will cut them off. I already bought the replacment rag joint.
LMC is the one I was looking at. The years mess me up. I have a 71 w/power. Putting a 69 in it. Column that is.
Old 09-02-2008, 12:00 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'd suggest calling their 800 number, but my experience with doing that with LMC is getting someone who just takes orders and doesn't know anything else but how to access the item in a computer.
What about one of the vendors on the board?? There are a bunch of them. Go to the link at the home page. These guys know these trucks and they can talk them while walking at the same time. Don't give up without making that call.....
Member Nr. 2770
Old 09-02-2008, 12:04 PM   #14
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thanks ChevLoRay
Old 09-02-2008, 04:28 PM   #15
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I am going to grind those 2 pins off.
Old 09-02-2008, 06:41 PM   #16
90\87Formula
90\87Formula's Avatar
The two pins/rivets are threaded; at least they were on mine.
90\87Formula is offline   Reply With Quote
Old 09-02-2008, 07:40 PM   #17
pickupman
pickupman's Avatar
these are the ones I sell for power steering box.. If it is a power steering box it will fit the manual boxes are different. steering column should not matter.
Old 09-03-2008, 09:28 AM   #18
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thanks... I almost cut it last night but my baby girl was sleeping. Then I came inside and saw this. Just didn't reply till this morrning.
That new coupler looks nice. It's all clean and stuff
Old 09-04-2008, 09:00 AM   #19
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Are the couplers the same for a 73' and up 2wd with p/s?
