Old 08-29-2008, 11:54 PM   #1
turbohacker
PISS POOR
turbohacker's Avatar
Air Ride Compressor question
I had been debating which compressor to buy when i thaught of an idea, why not use an old air compressor from a truck a/c system? I know they create plenty of pressure (+200psi i think) but what kind of CFM? Your input would be greatly apreciated!
Slammed 67 long bed with vette suspention build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=291149
turbohacker is offline   Reply With Quote
Old 08-30-2008, 12:30 AM   #2
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: Air Ride Compressor question
been done a hundred times already. the York is the best since it has it's own lubrication. Most modern AC compressors use oil in the freon/R-134 and aren't well suited. A york will fill a 10 gal tank in under a minute and un;ess you're super switch happy you'll never out run it.
The Oasis brand is basically a york connected to a DC motor so it can be mounted anywhere other than on the engine drive.
good info here:
http://www.kilbyenterprises.com/compressors.htm
josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
