It'd be alot cooler if you did
frame mounted battery
Anybody have any pictures of their frame mounted batteries? I'm thinking that this is where mine is going to end up.
Re: frame mounted battery
sorry this is the only pic I have..there is another battery on the driver side frame rail. click on the pic it will make it bigger
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
One day...
![]() Join Date: Apr 2008
No pics yet sorry, but do have a battery drop out box from CPP. it will be a sweet setup when i get it installed.
Seņor Member
Mine's back-halfed and the battery box is on the right rear corner with access from inside the step fender. No pics handy.
Custom Truck Lover!
I mounted two batteries. One on each rail behind the cab. Though, my frame is custom built so I dont know if you have room there. I do suggest you install a battery kill switch somewhere that is easily accessible. When you lay your truck out, you can not get to the batteries. So, if you show indoors or somewhere that requires you to remove your battery cable, you can show them the kill switch. Also, install a quick charge connection somewhere. That way if you are laid out and your battery fails, you have a spot to charge it.
Squarebody guy |
yeah, I already planned on having remote posts... problem I'm having is I'm mounting my airtanks in place of the saddle bomb gas tanks, and they take up most of that space, I'm running full exhaust on the inboard of the frame, so that off limits... and I really don't want it behind the rear wheels. I'm thinking of mounting one of those small batteries that Jeg's sells and mounting that somewhere towards the front.
![]() Join Date: Aug 2006
Here is what Fesler did on his bad a$$ blazer. It was a custom built frame but i am sure you could build something to work.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
