Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-31-2008, 02:18 PM   #1
Senator350
Senator350's Avatar
Cool My '69 4x4 "Workhorse" Build Thread
It's been a long time coming, since I bent the frame on my old '70, untill now...
In this thread so far:
1. '69 chevy bought from Maryland over the winter.
Chassis: Long Fleet K10, leafs, discs/drums.
Drivetrain: Mid 60's corvette 327ci, GM 202-160 .64cc heads, Edelbrock performer top end, unknown radical cam. TH350. NP205.
Exhaust: Rusted out Flowmaster headers, Rusted out dual 2.25" crush bent pipes, Rusted out 40 series 2.5" in-outs
1.5 replaced battery with Optima Yellow Top.
2. Proform Electric water pump installed.
2.3 (forgot!) PowerMaster high torque starter (black wrinkle finish) installed
3. Edelbrock #1406 Performer carb installed.
3. MSD Pro Billet dizzy & Blaster2 coil.
4. MSD 6AL ignition.
5. Flex A Lite dual 15" monster fans.
6. Removed interior (seats, seatbelts, & carpet)
7. Shaved firewall, replaced with vintage 1950's 'Fallout Shelter' signs
8. G-Force Racing cam lock harnesses installed.
8. GM P30 Hydroboost brakes w/ DIY4X custom bracket.
9. '00 Tahoe seats.
10. eBay stainless 1.5" headers (needed modification to #1 tube)
11. Mojave Heater install.
12. 100A idle-120A max Alt, Custom brackets, and radius tooth HTD belt from Jones Performance Racing
* Install plenum for FAL heater and run defrost ducts
* wire radiator probe for variable fan speed control
* wire new 0g. alt to batt.
* Install Summit inline radiator hose drain
* Install Flex-a-Lite inline temp sensor
* Modify hump for floor shift
* Cable shift NP205 from column
* B&M floor shift TH350
* new correct grill and fenders
* Late model motor mounts & droppable engine cradle from DIY4X
* Moroso oil pan
* Hooker Supercomp aero chamber mufflers w/ 2.5" mandrel bent exhaust & X-pipe
* NV4500 swap
* Replace the suspension with the suspension from my old '70
(FRONT: SKY Offroad dropped front spring hanger, GM 52" front leafs, DIY4X zero rates, ORD larger Shackle hangers, 7" Black Widwow greasable shackles)(REAR: DIY4X rear shackle flip, GM 63" leafs)
* Replace axles with the axles from my '70
(FRONT: '79 Ford Dana 60, GM DRW knuckles-out, 35spline Alloy USA stubs, Teraflex drive flanges)(REAR: GM DRW Dana 70HD, DIY4X disc brakes
* Flatbed with stake pockets.
* Stepside bedsides and original Fleet bedsides with stakes to intall on flatbed.
pictures to come a little later tonight
RN U OVR
Senator350 is offline   Reply With Quote
Old 08-31-2008, 02:37 PM   #2
Senator350
Senator350's Avatar
Re: My '69 4x4 "Workhorse" Build Thread
How I bought her:
RN U OVR
Old 08-31-2008, 02:46 PM   #3
Senator350
Senator350's Avatar
So far:
Replaced Edelbrock carb with correct sized Performer:
Installed Proform H2O pump.
Removed old AC/Heat, shaved firewall with Fallout Shelter signs.
Installed MSD dizzy & Wires.
Ran heater hoses thru firwall for Mojave heater.
Installed Flex A Lite 282 Monster dual 15" Electric fans with custom Fallout Shelter shroud/brackets
Wiring done:
RN U OVR
Old 08-31-2008, 03:00 PM   #4
Senator350
Senator350's Avatar
Oh lord... this stuff disturbs me...
Driver's floor:
Passenger floor:
Passenger rocker:
Passenger kick panel:
Passenger fender (front):
?ThE hUmP?:
RN U OVR
Old 08-31-2008, 02:45 PM   #5
msgross
msgross's Avatar
subscribed... love 4x4's
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-02-2008, 02:24 PM   #6
Yukon Jack
Yukon Jack's Avatar
Quite a project - have fun with the rust issues.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-17-2008, 10:07 PM   #7
Senator350
Senator350's Avatar
hmmm.
got my Mojave heater installed behind the glovebox. I drilled out the factory manual choke knob and used it in the stock location mounted to the Mojave's 4 way rotary switch... looks good for now (looks exactly like it always did ) but I'm talking to the guy at Wiseguy Customs to see if I can't get a LED lit translucent spider knob... which I'd put in the factory cig lighter location.
Also got my eBay stainless steel headers installed with the Percy's aluminum gaskets. There is a total clearance issue with my #1 plug... which I will inform the seller about. From his feedback comments, I can see that more than a couple guys have bought 67-72 Chevy truck headers from him. I'm not going to break his balls and mess with all the back and forth shipping... I'm just going to bring them to a welder and have them modified. six one, and half dozen the other.
I should have the Ignition and Coil mounted in the next couple days, so she'll be moving under her own power... Directly to the Exhaust shop and then the dump
WHAT?!? I have a truck full of construction debris from building a 800 square foot deck
RN U OVR
Old 09-17-2008, 11:00 PM   #8
skchevota
skchevota's Avatar
Looking sweet. Got to ask, did you have a surlpluss of fallout shelter signs?
The rust sucks, but take it one area at a time and it wont be to bad
skchevota is offline   Reply With Quote
Old 09-18-2008, 08:35 AM   #9
Senator350
Senator350's Avatar
To be honest, I was just cruising the webs and looking for vintage sheetmetal signs. I'm just-barely too old to go out stealing stop signs
I found these Fallout Shelter signs in MO, I think, on CL. The guy sold (incl shipping) them for 1/3 of what I expected to pay for two, so I bought six
The rust DOES SUCK. especially when it was so neatly concealed by the top dollar interior. Ah well... life gives you lemons...
At least I have a nice dash, not to be boastful
RN U OVR
Old 09-18-2008, 08:44 AM   #10
steelhorse
steelhorse's Avatar
Nice start of a project.Ill be the odd man out and say I like the original grills better.
steelhorse is offline   Reply With Quote
Old 09-18-2008, 05:27 PM   #11
Senator350
Senator350's Avatar
Sounds sane to me! I'm actually in the market for a correct inner/outer grill.
I'll let this billit joint go for cheap if anyone on the board is interested... especially if they have stuff to trade (**hint HUMP hint**)
RN U OVR
Old 09-20-2008, 10:21 PM   #12
Senator350
Senator350's Avatar
Ignition and coil mounted.
And more than a little wiring.
Still undecided on valve covers and wire looms. Is that patina look "in" on valve covers too?
RN U OVR
Old 09-18-2008, 01:53 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great start to the project, good luck with the rust issues!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-21-2008, 09:56 AM   #14
msgross
msgross's Avatar
the chrome looks good, depends on how much you want to spend. You could pull them off, hit the with a wire wheel and get some of the duplicolor annodized paint...
The Garage:
Old 09-21-2008, 10:03 AM   #15
Senator350
Senator350's Avatar
Anodized like 'anodized aluminum'?
I'm interested to know what that product will do.
How much do I wire wheel? just a scuff??? or take it down a mil?
I haven't ever noticed this duplicolor anodized
I have two extra sets of rusted chrome Edelbrock valve covers that could use a little TLC.
RN U OVR
Old 09-21-2008, 03:05 PM   #16
msgross
msgross's Avatar
If you have any bad spots I bet you could hide them on the backside of the engine (ie flip the valve cover around). I used a very soft "cupcake style" wire brush on the chrome trim of a center console and it cleaned it up pretty nice.
The Garage:
Old 09-21-2008, 10:08 PM   #17
Senator350
Senator350's Avatar
HYJACK
but it applies to my truck, so Neh.
still interested to know how much you wire-wheeled. specs of wire wheel?
RN U OVR
Old 09-21-2008, 10:12 PM   #18
msgross
msgross's Avatar
Originally Posted by Senator350 View Post
HYJACK
just cleaned it enough to knock the rust off of it... worth a shot, if not then just pick up some new chrome or original style covers...
The wire wheel I used was soft and hooked onto my angle grinder... might leave scratch marks but for $10 in paint and $10 for a wheel it's worth a shot.
The Garage:
Old 09-25-2008, 07:18 PM   #19
Senator350
Senator350's Avatar
well, got her started with open headers today. have to be very careful how long i let it run... my #1 plug boot hits the header tube, so i can't let her get too warm. will take the headers off for tranny swap, and bring them to the welder with some T304 that the header's seller will hopefully provide. lord knows it will be cheaper than footing the welding bill.
The short valve covers I had stashed wound up cleaning up nicely with just some naval jelly. I didn't have a fine cup brush, but I do have a coarse one. It cleaned up my hydroboost pretty well.
anyway, used the Ebrake and pulled her onto the driveway so i could get crane and creeper access to hopefully start pulling the auto tranny this weekend. there's an interesting bunch of steel bolted on from the original 4X conversion. I'll try to take lots of pics (like anybody wants MORE pics in this thread!) to see if any of this stuff can be identified.
Got the hydroboost bracket from the welder, prepped and painted it 'enamel black'.
RN U OVR
Old 09-25-2008, 08:20 PM   #20
Premium72
Premium72's Avatar
not feeln the fall out shelter stuff every where. liked it on the fire wall. but slap'd everywhere is a bit hokey. looks like a cool truck though.
Premium72 is offline   Reply With Quote
Old 09-25-2008, 08:45 PM   #21
Senator350
Senator350's Avatar
pure function, brother.
thanks. it's getting there
RN U OVR
Old 09-26-2008, 04:27 AM   #22
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
nice truck.. put the floor mats back in and you not know the rust is there..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 09-27-2008, 10:18 AM   #23
Senator350
Senator350's Avatar
until I cross a stream, etc...
RN U OVR
Old 09-28-2008, 01:39 AM   #24
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
yeah ive doen that, had a vw baja sink from all the holes in the floors when crossing a creek..lol..
Old 11-02-2008, 04:49 PM   #25
Senator350
Senator350's Avatar
couple updates..
Firewall is painted,
PSC power steering pump is recieved,
JonesRacingProducts alt is installed,
hydroboost is painted,
Hooker supercomps are 1/2 done (VHT red+clear)
new SS brake lines are installed,
new proportioning valve is recieved,
like new '00 tahoe leather seats are recieved,
and a new addition to the shop, should make all that rust repair a little easier )
RN U OVR
