11-16-2002, 02:33 PM | #1 |
help with glove box install
I bought a new glove box for my 72 Jimmy. The truck has a/c. Does any one know how to get the glove box in? I can't get it to fit. It is like they are supposed to go in from the rear. Any tips will be appreciated.
Thanks, LT |
11-16-2002, 02:48 PM | #2 | |
Bloo
are you sure they sent you the one for a A/C truck and not a non-a/c?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
11-16-2002, 02:52 PM | #3 |
Where's my beer?
Did you get one for a a/c truck? I believe the ones for a non a/c truck are different, can some assure this?
11-16-2002, 03:39 PM | #4 |
The AC boxes are shaped different at the rear but the front is still the same. I think originaly they did install these first, then the heater box. But you can slide it through the glove box opening one side at a time. Notice there are reliefs designed into the corners. Once its in... it ain't comin' out lol. You'll likely rip it to streads trying to take it back out.
11-16-2002, 04:17 PM | #5 |
Old member
A/C or non A/C Glove box
The A/C glove box if looking at it from the seat it will have a indention on the left side of it for the air connections. Other than that they are the same.
When you install it it will fold up a little around the conners, but it should be alright after installed. I always install mine starting with the left side first, it just seems to go in easier. Hope this helps.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
