Old 09-02-2008, 09:32 AM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Brake Question
Hey Guys and gals,
I plumbed in my hard lines and hooked up the power booster and master cylinder this weekend for my disc/drum setup, BUT in a schematic provided, I noticed they had a 10 lb residual valve plumb for the rear drum brakes???...
I think I know why they did this to prevent rear wheel lock up, but I wasn't sure if I needed to do this or is it in the prop valve??
Anyone done this???...if so, got any pics and where did you install this??
on the prop valve or closer to the rear axle??
Any help is much appreciated!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-02-2008, 01:19 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brake Question
here's a link to what I am talking about....thanks
http://www.mbmbrakeboosters.com/Tech...gurations.html
I have my power booster and MC on the firewall....
Geoff with a G
Old 09-02-2008, 02:58 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Brake Question
When I first read your post, I thought it may be something I wasn't aware off. Now I know for sure, it's something I wasn't aware of.
From the read part you posted, it looks like it's a performance type product for quicker stops???
I have never heard of this before but that doesn't mean it's not being used in some of these trucks. However, I'm not sure I understand why you would need a 10lb residual pressure component to keep the break shoes close to the drums. On my rear breaks, I just adjust them until they are barely touching the drums. That's about as close as you can get them for stopping purposes.
68gmsee is offline   Reply With Quote
Old 09-02-2008, 05:34 PM   #4
umwtnt
umwtnt's Avatar
Re: Brake Question
You normally only use a residual valve when the master cylinder is lower the the brakes. Like when the master cylinder is mounted under the floor boards. In our application there is no need for one. A 10 lb is used for drum brakes and a 2 lb is used for disc brakes.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 09-02-2008, 08:17 PM   #5
cparman
sharp as a marble
Re: Brake Question
residual check valves are for brake systems where the master cylinder is LOWER than the brake calipers or the wheel cylinders. IF you master is in the stock location you should not need them.
www.mpbrakes.com
I like these guys, and go to their web site, and to their FAQ tech help area and it will talk about check valves
cparman is offline   Reply With Quote
Old 09-02-2008, 08:47 PM   #6
LONGHAIR
Re: Brake Question
The residual valve is "built in" to the stock stuff. It is only necessary to "add" one in a "custom" application with a bunch of aftermarket "race" parts.
The point of the residual valve is to keep some pressure in the lines because of the springs that pull them back to the "resting" position.
Calipers don't have springs, they just "relax" when you let off of the pedal. Too much line pressure would cause them to drag against the rotors
LONGHAIR is offline   Reply With Quote
Old 09-03-2008, 08:16 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brake Question
Okay guys....Thanks alot for your responses.....I was worried I had to get that residual valve plumbed in too....I am so darn close to getting my project rolling I can't stand it!!!.....
Thanks again
Geoff with a G
