Old 09-02-2008, 11:38 AM   #1
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Unidentified object
I went to replace this Thingamajig shown in my hand (SEE PIC)and the guy at the parts store said that I should have one of those already fitted to the booster.."I forgot what the heck he called it" and not to bother replaceing the one shown in my hand and that I should remove it.
My questions are...
What is it?
What does it do?
Do I really have two of the same thing doing the same job?
Can I start over, and remove both and fit the correct replacement?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 09-02-2008, 11:54 AM   #2
Luvlegs
Luvlegs's Avatar
Re: Unidentified object
you already have the check valve on the booster (the other end of the hose is hooked to it) - I don't know if what you are holding is just an inline check valve or not but if it is, you don't need two... maybe the one on the booster was bad?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 09-02-2008, 11:57 AM   #3
eightbanger
454 MAKES IT ROAR
Thanks mate, that's what he called it! can I replace the one in the booster or not ? is that why the PO added another inline?
Nigel.
No more pain.
Old 09-02-2008, 12:03 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It looks to me like the one that is in-line is in the reverse position of the one in the booster. Can you separate them from the hoses, then plug the in-line one into the booster?? If so, and it is a good check valve, the hoses look like they would connect from the base of the intake to the booster and save you an elbow in the hose. Grammar is an issue.....
Member Nr. 2770
Old 09-02-2008, 12:25 PM   #5
eightbanger
454 MAKES IT ROAR
Originally Posted by LOW DOUGH View Post
Well, it should be a one way check valve used to keep trash from getting in the booster. I don't think the thing attached to the booster is one. Just the one in your hand.I forgot what it was called.
Thanks LowDough
OK! if thats the case what would a check valve in the booster look like?
Anyone got any pics?
Thanks Chevloray
Not sure if I can pull that piece out of the Booster, i'll give it a go.
Neither hose is long enough to go from Booster to Carb, would need a new peice.
Nigel.
No more pain.
Old 09-02-2008, 12:02 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
LOW DOUGH is offline   Reply With Quote
Old 09-02-2008, 01:08 PM   #7
463
463's Avatar
forgot what it was called.[/QUOTE] me too
they were installed on gm on or about 1978 up in Canada to prevent trash from entering the brake booster. the hose from that filter connects to manifold vac port at the back of a gm carb or a intake port just back of the carb. the truck will work as normal with or without the filter in the brake booster vac line.
Trueman
463 is offline   Reply With Quote
Old 09-02-2008, 12:35 PM   #8
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
you can pull that out of the booster. I have.. No problems. You might want someone else to chim in about pulling that out. I don't see a problem with that.
Old 09-02-2008, 01:28 PM   #9
eightbanger
454 MAKES IT ROAR
Well I suppose that about solves it, now I know what it is and what it does, I may still get a replacement and get rid of the inline one to tidy it up.
Thanks 463
Halleyluya to the 67-72 Chevy Trucks Forum.
Nigel.
No more pain.
Old 09-02-2008, 03:50 PM   #10
kwmech
GM installed that "filter" inline to prevent gasoline vapors from deteriorating the rubber diaphram in the booster. I put them in all my trucks
some booster rebuilders send them with the unit in the box
Old 09-02-2008, 05:27 PM   #11
eightbanger
454 MAKES IT ROAR
kwmech What should I ask for when ordering a replcement?
Is it still just called a check valve?
Nigel.
No more pain.
Old 09-02-2008, 05:38 PM   #12
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
It's a filter as said above ^^^^ NAPA PART #675-5136 Balkamp part, They do help with the rubber deterioration in the booster though.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
