Old 09-05-2008, 09:47 AM   #1
orange66fleet
Lowered in Cleveland
3 inch Z question
I have a move the front suspension up 3 inches utilizing the Z and have 2 inch lowering blocks and 5 inch springs in the rear, my question is, Do I need to move the motor down 3 inches to keep the driveline from having any issues. I know I have to work on the steering, but what else, driveshaft loop, ect.
orange66fleet is offline   Reply With Quote
Old 09-05-2008, 06:22 PM   #2
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: 3 inch Z question
You will likely run into the driveshaft hitting the cab and the tranny tunnel needing to be raised. Im not sure about lowering the motor mounts. If you didn't you would also have to raise the tranny crosmember 3". By now you should be well on your way to hitting the carrier bearing crossmember.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
