Throttle Cable/Return Spring setups
What kind of throttle cable/linkage is everyone running? What about a return spring?
I'm tired of mine trying to hang up all the time! |
![]() Join Date: Mar 2008
Re: Throttle Cable/Return Spring setups
Matt '65 LWB Fleetside '63 SWB Fleetside |
Hollister, CA.
![]() Join Date: Sep 2006
I used the original pedal, and just made a new rod out of aluminum. Tapped one side and L shaped the other end.
For the return spring, I actually drilled a tiny hole in the protruding pipe plug and hooked the spring there..... ![]() - - Here's a not so good pic: - - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
![]() Join Date: Oct 2007
67 Camaro 396/375 throttle linkage, Moroso return spring kit...
See the little tab on the thermostat housing? That is were the return spring for the throttle goes from the factory. There was also a little L shaped bracket that you could bolt on the housing. Lots of clean ways to do it, mostly depends on spring length and your accessories.
soon to be bagged64sub
I dont have a good pic, but I used all Lokar stuff (Kickdown, throttle peddle, bracket with springs, and Throttle cable).
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
