![]() Join Date: Jul 2004
Radiator that fits without breaking the bank ???
Need a 4 core radiator to fit a 1971 C20 to repalce the factory 4 core. Needs tranny cooler lines 12 inches apart and a 3/4 in. heater return fitting.
Past experience - ordered a 3 core 2 years ago for the 1970 from radiators.com or their cousin. Fits OK except the top metal bar is inverted and holds the fan shroud about 1/4 inch from from the brackets, fixed by using 1/4 nut as a spacer on the top screws, not the best looking fix but it works. Present experience - ordered a 4 row from Rock Auto - CU369 was the number I think. All was good, tranny cooler lines 12 inches apart, fit the pads ok, lower oulet was curved, but had the same inverted metal piece at the top that pushes the shroud back, just like the one for the 70 and had no heater return line. The killer was it was damaged in shipping so I sent it back. They sent out a nice looking aluminum piece with plastic tanks, but it would not fit the mounts, the crimp to the tanks make it too tall and wide to fit the brackets. So here we sit with a leaky radiator thats not worth fixing and don't know what or where to get a good one that actually fits without costing 3-4 hundred bucks. Any suggestions ? I also want to get a new 3 core for our 68, but not if it fits like the one we got for the 70, so I really need 2 that fit, a 3 and a 4 core.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() Join Date: Nov 2004
Re: Radiator that fits without breaking the bank ???
I got my 4 row from advance auto. They actually had it in stock. Fit great. It was an auto one too. A little over $200 w/ tax.
3 and 4 row have different mounting brackets. 4 row are wider. You need a set of "4 row brackets" to use a 4 core radiator. Top and bottom.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-07-2008 at 12:00 AM. |
Gone to greener pastures
![]() Join Date: May 2007
Why not get your old one recored?
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
![]() Join Date: Nov 2001
Why do you need a 3/4" heater return line? I'll have to check the radiator catalog, but I'm not sure you'll find one for our trucks. I'll go by and look at some catalogs today and let you know.
A buddy of mine owns a radiator shop, I'll be there laer today (Sun) and look up some info. If I remember correctly, a 3/4" nipple was for 73- later Big Blocks. Where does the 3/4" hose run to on yours? You only should have 2 hoses on the firewall & 2 into the motor. hmmmmmm I will get you more info later.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Firefighter
He needs the 3/4 return line because in 71 and 72 the heater core return line went to the passenger side top of the radiator, instead of water pump and block. Napa has them anywhere from $173.00 to $224.00 these are the correct sizes and shape with the correct outlets also!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Black and Blue - do you have any Napa part numbers for me - I checked Naponline and the prices were pretty high.
Try your local radiator shop. Last time I took a radiator in it was shot, they got me a new one the next day, $155 is what it cost me and it was an exact copy of the one that was shot. A lot of times they can get you a better deal than some part stores.
1969 4x4 Nothing beats a good rock drill and some dynamite |
Firefighter
Well I'm not at work so I can't find the part # to the 4 row, I think that these are all 3 row 3490 $173.89, 2526 $205.39, and 2528 $224.95. I'll try to find the 4 row part # tomorrow!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() Last edited by BLACK AND BLUE 67-72; 09-07-2008 at 04:49 PM. |
When I bought mine a year or so ago, I bought it from Autozone. They didn't have anything in stock for a 70, but did have one in stock for a 79 1ton.
Comparing the new one and my old one,,,,I couldn't find a difference in them. Tranny lines, correct attachments, 4 core, all the same. I'll look it up and see if I can get a part number. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
This is what I have used on all my vehicles, the last one I bought was for my best friends camaro 454 with a procharger it keeps that bad boy cool!!!
the best $150.00 you can spend...they are owned by griffin radiators same quality without the price tag,,best kept secret. http://www.northernfactory.com/
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
I went to the local Carquest & they had a direct replacement IN STOCK for my 72 with A/C and Auto Trans. It had the heater hose fitting and curved bottom spout. I think is was about $175 about a year ago.
How are the heater hose's routed when using the radiator? Do have have cap off the water pump or intake?
Some suppliers have the 3/4" hose outlet, some don't for the same application...
The part# your looking for will be a Ready-Rad/Modine part# of 433369. 4 row 3-1/2"" thick at sadddle mount tank seam. 28-3/4" core width (tank seam to tank seam) Have a parts store interchange THIS number to their brand of part#, then have them check their parts book (or look at the radiator) to see if it has the 3/4" hose outlet, some companies will, some won't. Now as for the fan shroud issue.... hmmmmmm.... the fan shroud mounts to the brackets if I remember correctly, not the radiator... Take the radiator OUT of the vehicle (if its not already) and re-mount the top brackets in the truck without the radiator in. Then mount the shroud., to check fit... Any questions, PM me I'm 5 minutes from the radiator shop, and I have a key... http://67-72chevytrucks.com/vboard/s...d.php?t=245126 Other option is... get a part# 433369 and have a quality radiator shop mount a brass 3/4" nipple into the pass side tank. We've done that alot.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 09-08-2008 at 08:47 PM. |
RadiatorBarn.com Thery are cheap. Not brass and copper but plastic and alum.
