Old 11-17-2002, 01:45 PM   #1
ocbaud
Garage Queen Material
ways to help mpg
okay, i seriously need to get my mpg up. i dont have a label thing to set my timing so i have to do that by ear. i also know nothing about tuning carbs either
ocbaud is offline   Reply With Quote
Old 11-17-2002, 01:47 PM   #2
Txstruck
Txstruck's Avatar
Keep your foot out of it! Seriously, I dont know much about carbs being that I dont even have one. DIESELS RULE!!
Steve
86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud"
Txstruck is offline   Reply With Quote
Old 11-17-2002, 02:06 PM   #3
Piston
Piston's Avatar
Stay off I-40 (It shakes the fuel out of the tank!!!!) lol
-Timing is a key factor but driving habits are the most important.(Bone stock would have been 8 degree's) Constant in/out of the gas ruins MPG.
-Of course engine health is a big part too, how do the plugs look? Color I mean... nice shade of tan? anything more and your hurting MPG.
-EGR operation. The Spring gets weak in the EGR and cause it to open too early.
- Choke adjustment. coming up on winter time, make sure your choke is releasing as soon as possible. It can account for more than 2 gallons or more per week if the pull-off is bad or the choke thermostat engages too long.
-Tire pressure - higher pressure = less rolling resistance/terrible ride
-engine oil viscousity too high will cause poor mileage
I know there's more im not thinking about, anyone else?
I'll be down there in 2 weeks, if you need help let me know.
We've got family in Moore and Edmond and will be there over thanksgiving.
Piston is offline   Reply With Quote
Old 11-17-2002, 02:15 PM   #4
ocbaud
i got no egr
i installed a block off plate for it. and i probably should change my plugs and wires, because i dont even remember the last time i did.
Old 11-18-2002, 12:18 AM   #5
78SilveradoSWB
78SilveradoSWB's Avatar
Lightbulb
Add a soft or hard tonneau cover or just remove the tailgate and install a net to improve the aerodynamics of the truck.
78SilveradoSWB is offline   Reply With Quote
Old 11-18-2002, 12:37 AM   #6
ocbaud
removing the tailgate would make things worse, or so i've heard
Old 11-18-2002, 01:12 AM   #7
78SilveradoSWB
Talking
Things loaded inside the bed would fall out Open pickup beds tend to add to the drag coefficient and thats why tonneau covers hard or soft and air dynamic shaped canopy aids in the drag coefficient which will improve mpg. Removing the tailgate helps in letting the air flow through reducing the air resistance. The more resistance on the object the more energy required to pass through it. Its the law of physics.
Old 11-18-2002, 01:14 AM   #8
Hooter
My other Love
Hooter's Avatar
Ah these truck have the aerodynamics of a barn door anyways. Don't stand on it, get dual exhaust and headers, make sure you have a good air filter, good tires and non of your brakes are sticking. Remove excess weight a.k.a wife
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-18-2002, 01:17 AM   #9
78SilveradoSWB
Hooter:
He's got everything except the wife, but he has a girl friend
Old 11-18-2002, 10:44 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Drive behind a semi all the time.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-18-2002, 10:51 PM   #11
ocbaud
i advanced my timing some more, and it seems like it is running like it was before we messed with it the first time, which means less power, and more mpg
Old 11-20-2002, 02:44 AM   #12
littlebubba
Carb adjustment
Whats the condition of your carburater? Might need a rebuild? Running too rich. Have you played with the wieghts and springs in the distributor? Give that a try. Use a vacuum gage to setup your carb. Alot of factors effect mileage. Tire size, rear gears, cam, intake, etc.
littlebubba is offline   Reply With Quote
