09-08-2008, 10:45 PM | #1 |
Navy Radioman Veteran
Trans fluid leak in new be-cool radiator
Hey guys,
I got the Flex-a-lite fans in today and installed them on the radiator. Got everything tightened up and fired the '87 up. Trans fluid flowing from both cooling lines. It's like the lines don't mesh up with the fittings in the radiator even though the fittings are tight. Suggestions?
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 |
09-08-2008, 10:58 PM | #2 |
Re: Trans fluid leak in new be-cool radiator
quick easy solution
stand alone auxiliary trans cooler Mark |
09-09-2008, 07:05 AM | #3 |
Good Thought! - I hadn't considered that. Thanks!
Ken
09-09-2008, 07:58 AM | #4 |
they may have a different flare on the end
09-09-2008, 08:29 AM | #5 |
That's what I'm thinking... i'll contact Be-Cool and see what size line / flare/ etc I'm supposed to use. I figured the stock lines would hook right up and be fine... apparently not.
Let me know when you're ready for the 700. I'm sure I'll have this leak fixed tonight one way or another and can meet with you sometime soon. Thanks! Kenny
09-09-2008, 08:41 AM | #6 |
i take it ,the leak is a weep not a spray
09-09-2008, 04:47 PM | #7 |
Parts and more parts
For the money that a "Be-Cool" costs, I would be burning up the phone wires to them.
09-09-2008, 05:08 PM | #8 |
I did, they were very helpful on the phone.. I'm almost ready to go home from work and apply their suggestions.... like I said earlier, their suggestions were more like "duh" questions on my part. We'll see in an hour or so.
Kenny
09-09-2008, 06:25 PM | #9 |
www.73-87chevytrucks.com
I would be interested in what you found. AFAIK the trans fittings never changed on these (or I haven't ever had any that did....
If you run and auxillary cooler, I recommend just putting it inline with your current cooler in the radiator.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-09-2008, 07:48 PM | #10 | |
OK... so I get home tonight, unhook the lines and the flared end of the cooling line should butt up against the fitting inside the radiator, right? There's nothing for the flared end to butt up against. Just threads so the line pushes all the way into the cooler. I looked on my original radiator and the one for the sbc and they both have a seat for the flared line to butt up against to make a seal. The new radiator doesn't. Apparently, there is an adapter of some type that screws into the radiator to allow the flared line to seal against the radiator. Frustrating.... I guess I should stick with computers!
09-09-2008, 09:43 PM | #11 |
OK... first, let me say that I feel like I just watched one of those V8 commercials and someone just smacked me on my forehead!
Sometimes the obvious slips right by me. Here's the finished product with the fittings installed. $3.99 in parts at Advanced Auto. The copper fittings were what the radiator was missing. Summit customer support said Be Cool didn't include them because they didn't know what type of transmission I was using. My response was, no one asked me either. Another vantage point IT'S A L I V E!!
09-09-2008, 11:46 PM | #12 |
It'd be alot cooler if you did
well I just read the last post... but for the record I had the right answer!
09-10-2008, 10:01 PM | #13 |
Thanks for rubbing it in!
