PITbut
Airbaggers. Where are you putting your tanks?
I have a 71 swb stepside with the fuel tank in the rear. Where are you airbaggers putting your airtank. I dont want to put it in the back of the bed, i want it underneath somewhere...
Im thinking of putting it inbetween the cab mounts on the outside of the frame.. Would that fit?? There is 35 inches between the cab mounts. the diameter of the tank is about 10 inches.... Anyone done this before??? basically putting it here, on the outside of the frame rail.. I dont have the cab on so i cant really get an accurate measurement... ![]() I was also thinking of using 2 5gallon tanks but the suicidedoor guy said that it would be best to run 1 8 gallon tank.... Thats a tough spot to find some room for.. |
![]() Join Date: Feb 2008
Re: Airbaggers. Where are you putting your tanks?
Hey lyrikc, I can't answer your question yet because I have not gotten my air tank. But, I would like to thank you for the picture because I have been trying to figure out where to install my mufflers and I believe you have given me my answer. I am running the big 70 series flowmasters, Initially measurement indicate I may be able to install them like you have. If I had the measurements of a five gallon tank I could measure under neath my cab, on the outside of the frame rails, and see if the tank would fit. My cab is currently set in place.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
#3 | |
PITbut
Specs: Length - 32" Diameter - 9.5" Height with legs - 11.5" Let me know sir... Let me know the measurements of your muffler i might be able to take a measurement for you. |
HA! Don't you remember me asking the same thing? I never did find a good place to mount my 1 gallon tank. I can't imagine mounting something bigger than that. It wouldn't fit anywhere along the frame rails without hanging lower where you would see it. The only spot I could find was behind the rear wheels in the fender area mounted to the frame. But them you have a big tank that you can see in the wheel wells. Good luck to you. I am just going to end up doing a static drop in the rear. I will be putting the air bags on the burb, along with the hidden reciever. I will just use that to tow with. After all, it does have the big block! For now! HAhA
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#5 | |
PITbut
I mounted my 2 3 gallon tanks between the two rear most crossmembers..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
PITbut
#8 | |
someday it will be done!
Thank you,I hope it works out like I'm thinking it will.
edc=engine driven compressor.I went junkyard hunting for an old york air conditioning pump and am plumbing it in to keep the air flowing.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
I don't know what this is going to do but here goes. .........It worked!
Ignore the wiring. Last edited by Painter D; 10-17-2009 at 04:07 PM. |
Good Morning Lyrikz,
I did some measuring under, around and anywhere I seen some space and it doesn't look good for you. As some of the others recommended you may be better off with 3 gallon tanks or just installed them in the bed. An idea a friend of mind made to me was to built a box to install tanks in and make them to look like tool boxes. Painted separate from the bed and maybe even a tool manufacter sticker on it to fool onlookers. Good luck and thank you for the offer to check my muffler fit. I will probably take off the cab here in a few weeks and will check it then. I do know it will be tight.
Active Member
I had two 400's on two 7 gallon tanks under my '00 GMC for years with no problems and never burned up a compressor, just a relay once. It now has a Oasis on it but is torn apart for a rebuild. i got a good deal on it or it would still have the 400's. Just bought the 480 dual pack for my '07 but it is not bagged yet. I think you will be fine. Wish I could help you out on the air tank problem. Not the easiest thing but I have seen trucks that used there frame rails for tanks.
'70 Chevy stepside, ECE discs & 4/6, '00 GMC ext. cab stepside, never ending project '07 GMC Crew Cab, 24's & 5/7 "We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing" |
#13 | |
PITbut
I WOULD run two tanks, outside rear frame rails, in front or behind the wheels.
#15 |
PITbut
#16 |
Commander Taco Bello
ok, first the feedback you can use... whoever said one comp per 3 gal tank hit it on the head. it's gonna take way to long to fill a 5 gal tank with one compressor. i run my whole setup off a single 3 gal tank with 1 compressor. when the tank is full (160psi) i can fill my bags to ride height all the way around. Then it takes about 2-3 to refill the tank.
that seems to work well for the "just gonna drop it at the shows". I will also tell ya that for the first two - six months, you'll play with them at every stop light you can. at least i did. especially if the wife or kids were with ![]() ok, the other thing for ya is a pick of my compressor, tank, gas tank and exhaust setup. i'm not sure if you can do this though since you're a step bed. i'm not sure mounting it under your cab is gonna work. you may run the risk of laying your truck down on the tank, or it hitting bumps in the road. you have to keep in mind that your truck MUST still move @ 10mph or so if you're completely aired out. if not, you're gonna be screwed if anything ever blows going down the interstate. |
#17 | |
Tasty Cakes!
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#18 |
not really because the frame bends up before the axle. that's why the bed had perches up front, and bolts directly to the frame in the back.
#19 | |
Tasty Cakes!
#20 |
Not sure if itll work but have you thought about under the hood maybe the firewall were the heater core goes
#21 |
Stepsides are A pain in the arse. If you aren't running a heater/ac box, you may be able to put the tank in the engine compartment. I never could find a good spot to mount it. My mufflers are even turned verticle, and there is still not enough roomto mount it on the inside of the frame rail. The only other thing I could think of was kind of a strange deal. I thought about putting a shelf across the trailing arms and mounting the tank and compressor to that. You would have to mount it with rubber mounts so that it could flex and move with the trailing arms. The only other thing I could think of was mounting the tank to the bottom of the bed just above the driveshaft near the front of the bed, by the driveshaft bearing. These are just a few different thoughts I had. Good Luck!
Shawn
#22 | ||
PITbut
I have two compressors for 10 gallons.. So, im kinda close to where we should be. I will be running two compressors and 1 5 gallon tank for the rear, then when i do the fronts i will add another tank. If it doesnt work out, then i will just have to adjust to how much i play with them. ahaha... I made a mockup of the 5 gallon tank and it sits up inside the cab area pretty well. I wont truely know until i have the cab back on. I will have some pics and what not when that tank gets here... Quote:
#23 |
My 64 has two 3 gallon tanks mounted on the inside of the frame rails under the cab... they fit perfectly...
#24 |
![]() Join Date: Feb 2007
U can put it here
#25 |
PITbut
