Old 09-13-2008, 05:04 PM   #1
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Rear gears on an '87 R10 Silverado
Alright Gurus,
I'm trying to find out what gears are in the lowrider. I checked the differential and no tag that I could see.
What were the options for my year truck?
Thanks in advance.
Kenny
87Lowrider is offline   Reply With Quote
Old 09-14-2008, 07:53 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Rear gears on an '87 R10 Silverado
A very good chance that they are 3.08 gears in that truck.
Old 09-14-2008, 08:13 PM   #3
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Pull the diff. cover check the side of the ring gear, there will be numbers stamped on it. You are looking for numbers such as 41:10 you divide the small number into the large #...41:10 = 4.10. I agree the most common ratio is 3.08 but you never know if someone changed it. Beside's changing the diff fluid is not a bad thing! Just remember to add G.M. limited slip additive if your lucky enough to have a posi !!
crawdadfox is offline   Reply With Quote
Old 09-14-2008, 08:52 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
2.76, 3.42, 3.73, 4.10...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-15-2008, 04:24 PM   #5
87Lowrider
87Lowrider's Avatar
ok.. I'll check it.
I know it's a pretty high gear. With the TH400 in there now, in 3rd, I'm only taching 1300-1400 RPM at arount 30-35 mph. If that's so, it should still be reasonable for cruizing at higher speeds.
Chris - thanks for the options!
Kenny
Old 09-15-2008, 06:47 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
http://www.csgnetwork.com/speedcalc.html
Use that and your RPM at different speeds to figure out your ratio.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-15-2008, 07:33 PM   #7
87Lowrider
87Lowrider's Avatar
Thanks... I'll play with it and see what happens!
Ken
Old 09-15-2008, 09:15 PM   #8
piecesparts
What size of tires are you running? The axle calcs will be easy.
Old 09-15-2008, 09:57 PM   #9
87Lowrider
87Lowrider's Avatar
I dont' know overall height yet but the sizes are in my sig.
Old 09-17-2008, 08:58 PM   #10
piecesparts
Well Pardner---you have 27.25" diameter tires on the front of the truck and 28.43" diameter tires on the back. The calculations tell me that the rear end is coming out at 3.3845, which is close to the 3.42 gears on a lot of trucks, so I would say that is where your at.
The difference in the calculations are probably due to the inaccuracies of what RPMs you have given for the actual speed on your speedo. There is a way to get the accurate readings on that also, but My guess is that you have a 3.42 rear end.
Old 09-17-2008, 11:00 PM   #11
87Lowrider
87Lowrider's Avatar
Cool - who am I do disagree!
Still not a bad gear for cruizing and a little stop light to stop light action
Thanks!
Kenny
