Old 09-14-2008, 12:52 AM   #1
mole2000
mole2000's Avatar
Question brake prop valve choice for disc conv on 1970 c10
I picked up this brake prop valve today. It came off a 1991 c1500 with RWAL. can i use it for my disc conversion on my '70 c10?
thanks,
tim
Last edited by mole2000; 09-14-2008 at 09:44 AM. Reason: input incorrect year model
mole2000 is offline   Reply With Quote
Old 09-14-2008, 07:25 AM   #2
cdowns
cdowns's Avatar
Re: brake prop valve choice for disc conv on 72 c10
disc conversion???? all trucks starting in 71 came with disc brakes
Old 09-14-2008, 07:44 AM   #3
LONGHAIR
I think he is refering to rear brakes? ....but my initial thought is no. I would not mix anti-lock parts into a non anti-lock system.
LONGHAIR is offline   Reply With Quote
Old 09-14-2008, 09:05 AM   #4
Boog
laying low
Boog's Avatar
But the 91 had rear drum brakes too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-14-2008, 09:35 AM   #5
mole2000
mole2000's Avatar
Sorry- it was late. And I had some problems thinking. I have a 1970 C10.
Old 09-14-2008, 12:53 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Mole, personally, i would either use a 71/72 piece, or, stick with your stock distribution valve on the drum/drum set up, and install an adjustable prop valve in the rear line, and then fine tune it all to where it is perfect.
Old 03-03-2009, 02:14 AM   #7
Ford Assassin
Ford Assassin's Avatar
I didn't know you could re-use the stock drum/drum proportioning valve when converting to front disc brakes.
I am in the process of finishing my disc brake swap on my '69 and I have a used '71-'72 booster, master cylinder, and stock disc proportioning valve. However the stock drum rear line that would go to the disc proportioning valve isn't even close to where it needs to be.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 03-03-2009, 02:46 AM   #8
spinning wheels
spinning wheels's Avatar
Ford Assassin, look up Classic Performance Products, (CPP). I am running their proportioning valve and it works fine. They also sell refurbished factory proportioning valves, but they cost more than their own product line.
I think you might run into the same problem that you have now, the proportioning valve being too far from your rear brake lines. Would it be feasible to change out the rear brake lines?
Like Longhorn said, you can also run what you have and add an adjustable proportioning valve. I believe Wilwood brakes makes a proven product.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-03-2009, 02:51 AM   #9
Ford Assassin
So if I run what I have already, do I bypass the rear line from the block and just run it into the adjustable proportioning valve? Or do I run the proportioning valve before or after the factory drum block?
Cable
Old 09-14-2008, 01:54 PM   #10
Sinisterspeed
Sinisterspeed's Avatar
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 09-15-2008, 09:31 PM   #11
mole2000
mole2000's Avatar
i will heed this sage advice. I looked to be sure and mine has no prop valve at all. I guess with drum/drum it didnt matter. I'll pick up one of the adjustable units.
Thanks all.
Old 03-03-2009, 05:13 PM   #12
Longhorn Man
the drum/drum piece is not a proportioning valve at all, just a distribution valve with a pressure switch and warning sensor. A stock 71/72 prop valve would be fine, you may have to rebend/add to/replace the line you are having issues with. If you want to add an adjustable one, I think adding it after the distribution valve would be best, that way the dash warning light isn't triggered.
