Old 09-15-2008, 07:18 PM   #1
Eyegore
What Hump?
Eyegore's Avatar
Oil Gauge Problem
OK the old oil gauge was not working not even moving when power was applied. I replaced it with another gauge and it powers up fine, but when I start the motor it pegs clear over to the right side, to the highest psi then it stays there when I turn the motor off, to the right side that is. After that I click the ignition back on to power, not cranking the motor, it then goes back to the left side of the gauge to the lowest psi while power is kept on. Can anyone give me a hint of what might be the problem and a solution? Is it the sending unit that is the problem? A while back at the autoparts store they showed me a completely different sending unit that is in there now, it was a canister type.
This is for a 1978 454 3/4 ton.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 09-15-2008, 08:16 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Oil Gauge Problem
sounds like a sending unit ... i always use the guages which arent electrical tho
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-15-2008, 11:07 PM   #3
salrod00
salrod00's Avatar
oil sending unit. you might want to take yours off first and take it up there with you. there are different psi ratings on those..oh yeah my ran around 8 bucks.. good luck.
salrod00 is offline   Reply With Quote
Old 09-16-2008, 06:09 PM   #4
Prong
My 79 did this--turned out to be the ground wire. Check out the ground leads that run from the loom to the 6 prong post on the cab wall (above and left of the fuse box).
Prong is offline   Reply With Quote
