09-17-2008, 07:41 PM | #1 |
wierd starter noise
i've noticed that my starter makes a hell of a lot of noise compaired to all the other old cars and trucks. theirs are quiet while mine makes a loud NENENENENE noise (trying my best to put it in words). i did have to replace my ring gear a couple months back so im hoping its not that. im thinkin its the cheap rebuilt napa one that the po installed. am i right?
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project Last edited by Camper Power; 09-17-2008 at 08:49 PM. |
09-17-2008, 09:17 PM | #2 |
Between Trucks...
Re: wierd starter noise
Sounds like the starter might need to be shimmed.
Beat it to fit, Paint it to match... |
09-17-2008, 09:46 PM | #3 |
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
09-17-2008, 09:49 PM | #4 |
Sisyphus was my mentor!
Is it actually starting the truck while making the noise, or do you hit the key a few times while it makes the noise & then it engages? It could be a million things... All easily fixable but not necessarily easy to diagnose...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
09-17-2008, 11:06 PM | #5 |
it does crank the engine when it makes the noise, and it makes the noise everytime
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
09-18-2008, 12:18 AM | #6 |
could be that it needs shimming as mentioned above, or also the nose bushing might need replacement, or both.
09-18-2008, 11:35 AM | #7 |
with the starter fully engaged with the flexplate there shoult be1/8th inch clearance at the bottom of the teeth if not shim till its in that ballpark
09-19-2008, 03:53 AM | #8 |
Not quite sure how to put this, but is your starter gear compatible with ring gear? Wrong pitch and it will eat ring gears. Had a heck-of-a-time figuring this out onetime.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
09-19-2008, 03:59 PM | #9 |
Sometimes Ive had to take a big rough file & file down the mounting surface of the drive end housing where it contacts the engine. The metal gets pulled up & spaces the teeth back too far. The shims just make it worse. Sometimes the aftermarket drive end housings that come with a reman. starter dont fit good.
