Old 09-17-2008, 09:29 PM   #1
69halfton
69halfton's Avatar
four speed?
just sort of thinking about a winter project for now.
how many of you guys have made the swap from an automatic to a standard tranny, specifically a muncie M-21 or M-22?
did you need the high-hump tranny tunnel, or did it fit with the low hump?
where did you purchase your transmission?
ballpark, how much did it cost to make the swap?
what shifter did you use (I've herd that a shifter for a 55 chevy with a bench seat works, but I can't actually remember.)
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 09-17-2008, 09:41 PM   #2
Mike C
Mike C's Avatar
Re: four speed?
I've made the swap in cars. Pretty straight forward. It will fit in any spot that the 3 speed will fit, might even use the same driveshaft, depending on the transmission.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-17-2008, 09:42 PM   #3
hchad18
hchad18's Avatar
Re: four speed?
The low hump did not work for my application. Bagged w/ post 73 front crossmember. An ear of the tranny was hitting the tunnel, not by much. I made my own. I used a hurst indy shifter with a short stick, it is perfect with bucket seats. With a bench seat you would need a longer shifter w/ a bend. Also I believe there are two different mounting brackets for the Hurst shifter. One that mounts it up high, which brings it way over the tunnel and one that mounts it to the side of the tranny. I have a friend that has a 56 chevy with the low one mine has the high one so I made a console. You can get both brackets and shift sticks through summit. In the picture the top of the boot is at the top of the shifter. Its a muncie 21.
hchad18 is offline   Reply With Quote
Old 09-17-2008, 09:44 PM   #4
larry may
Re: four speed?
I used high hump, but aMuncie m20 21 22 may fit okay under the low hump. Got my transmissions from muscle cars from the past . Saved them all these years switching from one hot rod to another. One of the members from Arizona had posted all you needed to install everything for around 1500 dollars. may have been 72 RS SS. not sure now. Not to bad of a price for a package deal. The parts I have have been aropund for a lot of years so not real sure what it would cost from scratch. But 1500 is a good price imo. But that is used parts. Good luck .Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 09-17-2008, 11:04 PM   #5
hchad18
hchad18's Avatar
Re: four speed?
I didnt say before but I looked around before I bought this m-21 from a friend for 500.00 w/ no bellhousing. They seem to be going for around 500-700 dollars depending on if they come with a shifter or not. Then of course you'd need flywheel, pressure plate ,clutch, bellhousing, pedals.
Old 09-18-2008, 07:01 AM   #6
Re: four speed?
The car 4-speeds will fit under the low-hump.I have slipped them in and even used the same hole that was cut in the floor for a 3spd floor shifter,like the "Indy" shifter.There is a Hurst shifter made for these trucks that will clear the bench seat.
Old 09-24-2008, 10:33 PM   #7
chevy29267truck
Re: four speed?
my 1967 chevy 3/4 ton truck when i got it had a 3on the tree i put in a 4 speed 4 in the floor i add the high hump i got a used four speed for $ 100 somthing or $200 somthing oh ok guys dont let any one take your four speed shifter,rod if you let me know and i give you the info how too get one
chevy29267truck is offline   Reply With Quote
