Old 09-18-2008, 11:56 AM   #1
Texas1971
Brake Pedal Switch
I believe it is part of a broblem I'm having and your threads lead me to think I need to check it. What does it look like and where is it attached? Does anyone have a picture? Many thanks for the help!
Texas1971 is offline   Reply With Quote
Old 09-18-2008, 12:03 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Brake Pedal Switch
Follow the break pedal up to where it's mounted and you will see it. It is round tubular shaped with a plunger on the side facing the pedel and a 2 wire harness plugged into the back of it. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-18-2008, 12:10 PM   #3
jef5150
Inline 69
jef5150's Avatar
under the dash, above the brake pedal this connector with white and orange wire is attached to it.
You can jump this connector with a piece of wire and if your brake lights come on its probably the switch...
also there is a little bit of in-out adjustment to the switch
jeff
jef5150 is offline   Reply With Quote
Old 09-18-2008, 12:20 PM   #4
Texas1971
That's what I needed! You guys are great! Thanks.
Old 09-18-2008, 01:38 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
We live for the questions we can answer!! I was at work or I would have posted earlier.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-18-2008, 01:57 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
let us know if that fixws it, this switch is not that commonly a problem.
Old 09-18-2008, 02:21 PM   #7
Texas1971
Longhorn,
Will do! I had brake lights (in fact all lights) prior to turn signal switch replacement. Now I have no brake lights. When I prssed the brake pedal before, the right front turn signal and dash indicator would come on !!???
And, the BRAKE warning light still stays on when the key is turned to the right. I am thinking that it will boil down to a ground problem. I'll post the results, and THANKS!
Old 09-18-2008, 02:32 PM   #8
Longhorn Man
your brake light in the dash indicates a hyd problem, nothing to dowith the brake light circuit going to the back.
The front turn signals coming on, makes me wonder if you have the flasher missing from the fuse box for the 4 ways... which 'could' cause no brake lights. It also tells me the button for the 4 ways is in the on position.
The fact that they come on when you hit the pedal, tells me the switch down there is working, and the power is getting to the turn signal switch at a minimum
Old 09-18-2008, 04:42 PM   #9
Orange
Licensed to Thrill!
Orange's Avatar
Here's you a pic of the switch itself:
But like Andy said - it's most likely something else. When my light was on, it was my proportioning valve.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 09-19-2008, 08:37 AM   #10
Texas1971
Thanks a million for all your help! Believe it or not, after a year of fussing with the electricals, lights, signals markers, etc, everything works just the way it's supposed to. HOWEVER, I must have screwed up the horn because that was working before replacing the turn signal switch. I had a feeling I may have shorted something. Why? Because when I was testing for power with the signal switch just hanging there, the horn went 'honk' and nothing since. I think there is a breaker or module up front??? The goal is getting it inspected this weekend for sure. Thanks again.
