Before I order my 4 link, I have one question.
How come I have never seen a 5 link? That is; 2 parallel bars (one on each side of the frame rail) and a pan hard? I have never seen this installation so Im sure there has to be a reason.
Im kind-of-a novice fabricator and this would be easy for me. I dont feel comfortable with the install of the triangulated 4 link. And the parallel bars looks easier to install but I will have to fab the mounts to the rear end like jlaird did to get it parallel with the ground. Anyway, any comments on the 5 link? Thanks -Marc
Blazer Project |
#2 | |
Re: Before I order my 4 link, I have one question.
O, I was under the assumption that a parallel 4 link was only limited to the type that has the two bars vertical (one on top of another) on he outside part of the frame. But that makes sense.
Blazer Project |
Yeah that's what a parallel 4 link is, and that's the part where it gets its name, but those have nothing to center the axle from moving side to side so that's where the panhard or watts link comes into play.
Stirrer of the Pot
I have a parallel 4link + panhard. did you order your kit yet Marc?
Dustin, no I didnt yet...
Blazer Project |
A 5-link is 2 forward loer bars an upper frt wishbone and 2 rearward facing "lift bars" on swinging pivots. super lift capabilities and travel. Does use up quite a bit of chassis space but nice when done right.
We build links to spec if needed. |
![]() Join Date: Apr 2004
Who are you? Do you have a website?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
I think he just added that.
Stirrer of the Pot
that sounds like a 6 link.
You will need to sign up as a vendor before advertising product for sale.
#13 | |
Head Peon
![]() Join Date: Dec 1999
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
Stirrer of the Pot
Leave the pot stirring and pissing contests elsewhere. Thanks.
#15 |
#16 |
Stirrer of the Pot
Marc, getting back to your OP of 'why don't I see 4link + panhard' here's the one we installed this summer:
![]() ![]() and here's my favorite shot. you can see the 4 link and barely see the where the panhard mounts to the axle outside of the notch. ![]() Last edited by Dustin07; 10-23-2008 at 01:15 PM. |
#17 |
Yes what he said a triangulated with rear lift bars is a 6-link. a wishbone with rear bars is a 5-link
#18 |
Stirrer of the Pot
that would make sense.
#19 |
Its Deja Vu time again
A lot of the Jeep guys run the Triangulated 4-link because they want max suspension travel up and down for crawling over things without worrying about the track bar binding.
Heck some even run it dual triangulated opposed to the outside bars being parallel. |
#20 |
Junior Member
![]() Join Date: Jan 2005
Not wanting to hijack the thread but does one ride or handle better than the other - triangulated 4 vs. parallel 4?
#21 |
#22 |
#23 |
Yeah look up above it wasn't in his sig.
#24 | |
Junior Member
With the exception of our S-10 setups... that is the way most of our AirBars are. They are pretty common piece. |
#25 |
![]() ![]() Last edited by Shane; 10-21-2008 at 11:08 PM. |
