09-19-2008, 09:50 AM | #1 |
Between Trucks...
Vortec Heads/Accessories
I'm considering getting this motor at some point.
http://www.jegs.com/p/GM+Performance/813788/10002/-1 It has Vortec heads. Will my driver's side alternator mount bolt up correctly to these heads? I have a 350 in my '69.
Beat it to fit, Paint it to match... Last edited by Sinister; 09-19-2008 at 09:51 AM. |
09-19-2008, 09:55 AM | #2 |
newly minted old timer
Re: Vortec Heads/Accessories
on my 72 everything bolted up fine. i did have problems with all the brackets that bolt to the intake manifold bolt. the stock manifold the bolt holes are slanted, the vortek are flat.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
09-19-2008, 10:22 AM | #3 |
Between Trucks...
Thanks for the quick reply. I think I'll be O.K., I don't have anything that bolts to the intake.
Another quick question, what would the size of the flexplate on a '69 with a TH400 be?
Beat it to fit, Paint it to match... Last edited by Sinister; 09-19-2008 at 10:53 AM. |
09-19-2008, 11:49 AM | #4 |
http://67-72chevytrucks.com/vboard/s...d.php?t=305672
not sure on the flex plate.. but there is a link to photos about the alt bracket..the vortec heads are in the photo
09-19-2008, 01:11 PM | #5 |
Flexplate diameter wont matter on the trans as much as the motor & starter. If you get a flexplate & starter for an late 80's to early 90's 5.7 W/th400, you should be good to go...
