09-22-2008, 12:40 PM | #1 |
Picture needed
I am almost at the stage where I will be reassembling my box and I need a pictures of a full size fleetside box from all angles.
Is there a FAQ to reassemble a box? here is a link to what I want. http://www.67-72chevytrucks.com/vboa...hp?t=222007]My scroll down about 1/4 of the page. |
09-22-2008, 01:38 PM | #2 |
Active Member
Re: Picture needed
I just put mine together a few weeks ago. I had the two sides, wheel wells, front panel, and tailgate off. Also, had all the bolts of the bed to replace them and installed pads under the bed.
Specifically what pictures are you looking for? There's lots of angles. |
09-22-2008, 01:43 PM | #3 |
Re: Picture needed
What exactly do you need to know. Here are a few pics from my bed I assembled. They bolt together pretty easy but you should have somebody to help.
09-22-2008, 04:58 PM | #4 |
Re: Picture needed
I need pictures of the wood bed option. I don't know where the holes go to mount it also need to see how the rear support goes on. I like the idea of painting it before reassembly. I wasn't going to do that. Should I paint the strips the same colour as the truck? I've done a ton of custom work to it. I've shaved the pockets removed them inside the box. Boxed the lip where the pockets were. Shaved the gate front and back moved the opener inside. I'm worried about the fit and whether it will go back together at all! Mine was in bad shape. I have all the parts fixed or replaced so we'll see! I was told to reassemble it on the head board then square it and so on. I wish I had a good step by step with pictures.
09-22-2008, 07:43 PM | #5 |
Re: Picture needed
Not sure exactly what you need, but I have a few pics of mine. Send me your email address and I'll email them to you.
DStamp42@woh.rr.com
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
09-22-2008, 07:53 PM | #6 |
Re: Picture needed
I painted the outside of the quarters after I assembled the bed. Maybe you should just primer yours and assemble it since you don't know if it will fit back together because of the custom work. Also it may be easier to paint the inside of your bed since there would be no floor. I would paint the strips body color or get polished stainless steel ones. I can't help you with any wooden floor pics. Good luck with it.
