09-24-2008, 02:40 PM | #1 |
Power Steering Hose Dilenma!!!
Guys I have finally had it with this freaking power steering hose. I have ordered three different ones and none of them will fit properly.
I am using brand new parts based on a 71c10 2wd factory set up. The pump and the steering gear box are bolted and fit perfect so I know I have the right parts however the pressure hose is the one that I am having a problem finding the correct one. Does any of you have the part number or a suggestion of what hose I should use? In fact if you have a picture of the hose you used it will help me greatly. Downhere this trucks are NOT common at all like a camaro, corvette or a chevelle. Thanks Albert
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-24-2008, 02:42 PM | #2 |
Re: Power Steering Hose Dilenma!!!
The ones I'm familiar with come with a brass fitting that screwed into the back of the pump - then it all fit together. I'll see if I can find the part number... it came through Advance Auto.
Can't find it just yet - check in my gallery and you can see the pics of my pump and lines - it's a 6 cylinder though but I think the fitting should be the same..... if you can see it in the back of the pump.. best I can do at the moment, don't have my files with me.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 09-24-2008 at 02:48 PM. |
09-24-2008, 02:56 PM | #3 |
thanks I will check your gallery.
\ The biggest problem is the 90 degree behind the pump..
09-24-2008, 03:15 PM | #4 |
I bought one for my 69 K20 and it fit perfectly but when I bought one for my 70 K5 it was way wrong. Ended up buying another one for a 69 K20. Course there is absolutely no difference in that area of a 69 K20 and a 70 K5 so I can't imagine why they were different.
Unfortunately it sounds like your just gonna have to keep trying different ones. Maybe give one for a 69 K20 a try - the 4wd's engine is set back a bit more but it still might work for you.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-24-2008, 03:41 PM | #5 |
Always on the hunt...
Hey Albert, after trying several different pressure hoses for fit & finished look, the one that I liked and have been using on small blocks both C & K series is a Parts Master p/n 71065, I added a couple of extra pics of this pressure hose installed on 68 C/10. Good luck on your hunt!
09-24-2008, 04:01 PM | #6 |
Need a bigger hammer..
For my BBC I brought my entire old hose to a hydraulics shop and they brazed on some fittings and made an entire new hose out of regular stock. so now when my hose get old and brittle I can just have a short length made up and bolt it to the fittings..
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
09-24-2008, 05:47 PM | #7 |
Guys Thank you!!!!!!!!!
Classic Bowties big Thanks for posting picts!!! It helps me alot, I am going to try to find it tomorrow morning.....
09-24-2008, 05:58 PM | #8 |
Wide n'Low
For future reference I have found that http://www.rockauto.com/ is a great source for looking up not only part numbers, but many a picture of the actual parts are often there as well. Then I call the local shop with the number which makes the trip a one time deal instead of trial and error.. Hope it helps,
Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
09-24-2008, 06:09 PM | #9 |
thanks Drew!!!!
09-24-2008, 06:20 PM | #10 |
I had a similar problem finding one that wasn't..sorta bound up & twisted badly. I ordered another new one from GMC Pauls, it fit like a glove no binding, easy no leak install. I think mine was the angle and incorrect position of where the 90 was swedged.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-24-2008, 10:08 PM | #11 |
Sammy do you have the part number and picts?
09-25-2008, 06:25 AM | #12 |
No but was easy to obtain. I just went to GMC Pauls site. it was more expensive probally but figured I would use a known stand by your part board vendor. And it worked great for me after spending 3X's for others. Having ordered from him before if it didn't work I was going to return it.
