Old 09-24-2008, 10:55 PM   #1
Hoffman65burb
Hoffman65burb's Avatar
Lower control arm ball joint question
Anyone else have a REALLY hard time pressing these ball joints out? been throwin tool's for half the day trying to get it out. Oxy acetylene tanks were empty
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 09-24-2008, 11:17 PM   #2
63Belair
Re: Lower control arm ball joint question
I ended up using a small grinder to cut the rivets on mine
63Belair is offline   Reply With Quote
Old 09-24-2008, 11:22 PM   #3
Hoffman65burb
the lower's are riveted?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 09-24-2008, 11:23 PM   #4
63Belair
My 62 was
Old 09-25-2008, 01:47 PM   #5
rickf
rickf's Avatar
Same on my 64 C10
rickf is offline   Reply With Quote
Old 09-26-2008, 03:00 PM   #6
jason65
Registerd User
jason65's Avatar
My 65 is a press in. It was stubbern at first so I got a bigger hammer. From what I've seen c10 and c20 are both press in lowers and bolt in uppers.
jason65 is offline   Reply With Quote
Old 09-26-2008, 04:59 PM   #7
salazar44
65 - Chevy C10
salazar44's Avatar
dude... check out my blog. I have instructions step by step on how i did mine. it IS a major pain. MY BLOG
Good luck man, hope it helps!
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 09-26-2008, 09:27 PM   #8
Hoffman65burb
thanks!
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 09-27-2008, 12:53 AM   #9
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
I hit both of mine less than 5 times each with a 3lb sledge hammer and they fell out. When in doubt, get a bigger hammer. Your not going to hurt the control arm, whack the s**t out of it.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 09-27-2008, 02:10 AM   #10
salazar44
65 - Chevy C10
salazar44's Avatar
true! the only thing is that our were probably never detached so its gonna take more than 5 wacks!
VIC
Old 09-27-2008, 10:02 AM   #11
kdrodworks316
KOFFIN DRAGGER
I know the upper had been changed, not sure about the lower. I supported the control arm with 2 floor jacks, 1 inside the arm towards center and 1 outside at the edge. Now when I say "5 whacks" we are talkin full swing man whacks hitting the stud part as hard as possable. I am 265lbs, I can whack something pretty hard. I also had the front clip off the truck, so I kinda cheated.
Old 09-27-2008, 02:32 PM   #12
Hoffman65burb
Haha, well, stupid me, dident read the instruction's on the ball joint press tool (Im a guy, i geuss its in my blood) and i was using the wrong fitting and doing it from the wrong side! both lower's are out and waiting for the new front end rebuild to come in the mail! thanks for the info everyone
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 09-27-2008, 09:10 PM   #13
protrash64
Resistance is Futile
protrash64's Avatar
I used one of the large C-clamp deals to remove my ball joints but could not get them back in using the same tool. Had to use a press.... mite have been easier if the control arms were mounted; in case you have trouble.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-27-2008, 09:35 PM   #14
KIC
1960 GMC Burb
KIC's Avatar
On my 60 I drilled the original rivet out, ground it flat, used large hammer to punch them out. Then got a larger sledge hammer and got the job done.
Good luck, it sucked for me.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
