CAN ANYONE TELL ME IF YOU CAN BY A KIT TO PUT THE GAS TANK UNDER THE BED ON A 68 GMC WITH LEAF SPRINGS.
Fabricate till you "puke"
Yes, a blazer poly tank kit will fit. You will have a little fab work to set up the fill spout, but here is a link... http://www.classicheartbeat.com/cata...tank%20kit.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
THANKS FOR THE HELP. THIS MIGHT BE A DUMB QUESTION BUT WHERE DOES THE FILLER COME THROUGH.
i have seen flip out sidemarkers, flipdown taillites, gas door welded to the side of the body......lots of innovative ideas! If you check classic heartbeat site, there should be pics on the side marker fill..... http://www.classicheartbeat.com/mark...t_gas_door.htm
WHAT DOES THE INSTALL LOOK LIKE. IS IT TUCKED UP UNDER THE BED WHERE IT IS NOT NOTICIBLE. I LIKE THE IDEA OF IT . I JUST HAVE NOT SEEN ONE INSTALLED.
I havent installed 1 yet, but have been lookin at the kit pretty hard! From what I undersand , the tank hangs about 5-6" below the rails......does also stick up above the rails,requiring some trimming on 1 of the bed rails. Ill leave the details to the guys that have "been there" (dont want to steer you crooked!)....good luck......crazy man
