09-25-2008, 03:19 PM | #1 |
Rebuilding Q-jet carbs.....any good books???
I am wanting to rebuild the q-jet in my 79...is there any good books or online refrenses I can check out??? I don't simply want to tear it apart and put it back together.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
09-25-2008, 03:50 PM | #2 |
My truck is an alcoholic
Re: Rebuilding Q-jet carbs.....any good books???
Funny you ask..
Cliff Ruggles is a guru with Qjets, I have this book and I have learned a bunch from it, and I was able to rebuild and modify them before I got it. Now I make them run better and I have a reference as to what parts I need and where to get them. Its not how to put a gasket kit in, its how to rebuild them, that includes throttle shaft bushings (easy to do) main jet well plugs (even easier to do), and tuning it for power, economy, and drivability. You can get it from a number of places. I ordered it direct from him in Ohio, and got some throttle shaft bushings at the same time. Now I need ethanol friendly accelerator pump diaphragms, since they dont come in any of the kits. Cliff's website There are a couple other books out there, and if you want I can find the links. This one has a bit more info in it than one of them, and is on par with the other one. Last edited by Thumpin455; 09-25-2008 at 03:54 PM. |
09-25-2008, 04:12 PM | #3 | |
09-26-2008, 04:45 PM | #4 | |
Insert Witty Text Here
Slonaker |
09-26-2008, 05:12 PM | #5 |
09-25-2008, 04:14 PM | #6 |
Awesome seems the book I ordered is the same one you are talking about!... Also is there a electronic choke conversion??
09-25-2008, 04:30 PM | #7 |
I swap the electric chokes over from carbs that have them to carbs that dont. Not that difficult to do provided they have the right bosses and throttle shaft pieces.
09-25-2008, 04:49 PM | #8 |
Can you explain to me how this choke works?? I dont see any heat tubes or anything.... this is the carb I am going to be rebuilding and the intake I am going to use after its blasted. its a edelbrock spread bore intake and the carb that came on my truck...
