sorry i have to ask but:
Has anone ever repaired a gas line leak on a (eeek) a 90's ford taurus. it is a plastic fuel line from tank to motor and new cost a couple hundred. Is there a splice for this. any help would be great. Lots of pressure and do not think hose and clamp fix would hold. Just fyi it's not my car, no really, i'm serious, just trying to help a co-worker. If its any consolation the car was given to her. free is free. Gary
Re: sorry i have to ask but:
There are compression type fittings that will hold the pressure also pressure hose to go with them. I would try a hose shop. My entire fuel injection system came with hose.
69 Chevy 4x4 383 Power ![]() |
Yes if you get the right ferrule size you just snug up with a wrench. Do not over tighten or you will collapse the plastic pipe By the way my parents live on a farm in Severy Kan. not too far from you.
69 Chevy 4x4 383 Power ![]() Last edited by haysonj; 09-27-2008 at 09:26 AM. |
Sierra Grande Club
You may want to check this but your hose is probably a metric size. I would call NAPA and see what they have.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Firefighter
Yes NAPA has the repair kits for plastic lines, or at least our store has it in stock, it is made by Dorman and relabeled under Balkamp for NAPA.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
its all about the +6 inches
This thread has nothing to do with trucks, so it is getting moved.
General discussion is the perfect place for this kind of thread. Post moved. |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Through my past experiances, the best way to fix that is to get atleast 30 yards of green fuse material and slide into the leaking gas line. Get at the other end and light it. Then get back far enough so you don't get hit with flying ford parts. lol
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
I am sorry for your pain. My kid went haywire and bought a used Tarass. Eventually the repair costs were approaching the original purchase price (around 5K) when the tranny puked for the second time in 20K miles. While she owned it we found that it takes about 16 hours to r&r the dash to replace the heater core, you have to pull have the motor mounts, ps pump and a bunch of stuff to replace the water pump. Takes about 4 hours and there is one bolt that is a blind r&R. Exhaust manifold crack and all the ones at the wrecking yards are cracked too. Bought stock in JB weld. When she gets it fixed tell her to sell it.
Oh did I mention that the ECM start puking every 1500 miles, are not made anymore, you just get someone elses that puked and was fixed enough to last 1500 miles. The mechanic that was replacing them under 90 day warranty (kid was driving 70 miles per day to school and back) finally paid us to not come back because the labor for r&r was not being reimbursed by the co that remanufactored them. |
#10 | |
blood type; Retumbo
Dorman sells a kit for fixing these lines. we have it at work and it is sweet. call around to see if one has it. it uses a special tool to install the splice. |
#11 | |
~Rest In Peace~
what engine was in this tauras ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
~Rest In Peace~
i know you dont want to hear this but i would just replace the fuel lines if i was keeping the car i wont trust plastic repair kit ,to me thats just a temp. fix ,but again i was a ford mechanic and has been brainwashed to sell sell sell
good luck
