Old 09-30-2008, 12:33 PM   #1
olivedrab
I need advice- 72 2wd to 4x4
I have a 72 gmc longbed 2wd. I am working on making it a 4x4, I got the donor truck for parts and will be getting the FGB52 kit from diy4x.com.
I know atleast one of you out there has done this or know more about it than I do. Any advice on problems I might run into would be great.
87 chevy-350 tbi-4x4-swb-4" lift-37inch claws
72 gmc- 350 carb- 2wd-lwb, soon to be 4x4?
olivedrab is offline   Reply With Quote
Old 09-30-2008, 01:48 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: I need advice- 72 2wd to 4x4
What year is your donor truck and is it also a lwb?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-30-2008, 02:07 PM   #3
FormerMember
I've done this. Pics and build in my sig.
No major problems. I also used DIY4x4's engine crossmember kit.
FormerMember is offline   Reply With Quote
Old 09-30-2008, 02:25 PM   #4
olivedrab
GRENDEL- if I am using another small block in place of a small block will i need a new crossmember?
yea I have studied your build up and thats where I got the idea from. Im sure I will be asking you more questions
Old 09-30-2008, 02:30 PM   #5
FormerMember
Well, the 2wd cross member(anchors your engine and front suspension) will be in the way of your suspension and axle.
You at least need a 4wd cross member. I have one from a 71 K5 if you want it.
Old 09-30-2008, 02:39 PM   #6
olivedrab
what about the 4wd cross member off of the donor truck will it work?
Old 09-30-2008, 02:23 PM   #7
olivedrab
the donor truck is a 85 k10 swb.
I was figurin on using the axles from it along with the transfer case, transmission, and engine. I know I will need a different drive shaft but those are problems to worry about after its done. My main concern is hanging the springs in the front.
with that kit it says i will need a set of 52" springs which is what the donor truck has.
Old 10-01-2008, 09:25 AM   #8
FormerMember
Tell Kert I sent him to you, when you order.
(Not worth anything to me, beyond that fact that he's my friend)
Old 10-01-2008, 09:36 AM   #9
olivedrab
alright, will do. I should be ordering that kit within the next month or two. I have got to work on the wifes cadillac...
Old 10-01-2008, 09:56 AM   #10
Yukon Jack
Yukon Jack's Avatar
If you go to the FAQ section there is an index and it has a link to a thread or two about posting pics. If you're still having trouble, PM me and I'll try to help ya.
Old 10-01-2008, 02:19 PM   #11
olivedrab
Old 10-02-2008, 12:49 PM   #12
olivedrab
hey grendel what would you recomend using to cut the whole in the frame for the rear part of the spring? i have a few ideas but yet you have done it before...
also did you have any problems with your transmission linkage after it was all said and done?
