Sierra Grande Club
Headlight upgrades
I’m considering upgrading my headlights (all 4).
So what are my options here? M&H can convert these to halogen sockets. (I automatically though thought of the newer style lamps with removable lamps. IE: H4 etc. but not sure if that’s what he meant and will have to call back.) I’ll have them do the relay upgrade to get power from the battery. ![]() But do I really need H4 style lights? What are my options far as lights available and what works good? Anyone have a source for headlamps? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Out of the carpool lane.
Re: Headlight upgrades
If you do the relay conversion, you might find that you're content with just that. You really won't find any brighter output with H4 style lamps unless you go with a higher wattage bulb behind them and anything higher than 55/60 is illegal. That being said, for awhile I was running 80/100 in my H4 lamps, but had them in a lowered truck, pointed down a bit more than standard.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 09-30-2008 at 02:42 PM. |
English Chevy Owner
I'm going to be fitting a HID (High Intensity Discharge, you may call them Xenon over there) conversion to mine as they have come way down in price. I have a conversion kit to go in my daily driver Isuzu Trooper as it has really weak lights too. I know a lot of people running these kits over here and they give a huge amount of light. They get around the relay issue as the power is taken straight from the battery to the ballasts and the original wiring is used just to trigger them. Plus they only draw 35 watts yet give out around 3 times the light of a standard 55 watt halogen bulb.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission Last edited by Lippyp; 09-30-2008 at 02:48 PM. |
well....wattage does not neccesarly mean more light for example a standard sylvania h4 bulb can supply about 55w...now if you are running a HID kit...they run on 35w of power and produce amout 10x more light. i do h4 conversions every weekend for chevelle's trans am, c10's motorcycles...anything....hid kits have come down alot in price and they are the most bang for the buck compared to any light on the market...they used to be 300 for a kit...now you can get them alot cheaper....buy they sealed beam conversion its like 50bucks from brothers for 2lights....then the hid kit for about 100....and spend about 30min and your done....there will be no need for you to upgrade your high beam headlamps
#5 | |
its all about the +6 inches
I would honestly start off with relay upgrade, cleaning the grounds on the core support both where the lights ground, and where the support is grounded to the battery, and double checking that they are aimed properly. These 3 things will do wonders... pluss, you'll need to do it when you put better lights in anyways.
don't bother with the hid kits, your lenses aren't meant for that kind of light and it goes everywhere. essentially the hid kits are too bright for your housings. the absolute best lighting you can do for these trucks would be retrofitting a set of projectors into the headlight housings. you would have to start with the euro lights from lmc truck (something with a clear lense) and fab up a mount for the projector, that way you get the proper lens and focus for the brighter hid kits. i did this on my old 05 tundra and it was amazing the light compared to a drop in set of hid lights.
HA.....LOL.. i have been putting in these kits forever without any trouble....anybody can put whatever kind of light they want on their truck but nobody wants to be retrofitting projector lenses in some old houseing and making all kinds of modifications. it really isnt that hard to order a kit from any hid place and order a sealed beam conversion kit from brothers, or anyother place and put them on. takes hardly any time maybe an hour for everything and then your done. nothing burns or melts or causes problems, its just like any other bulb, just doesnt use a little filament to make some yellow light.
right, i never said anything burns or melts, but the light looks like crap and has tons of glare
projectors are the proper way to do it, ask anyone. hids are a cheap option, but if you really want to do it properly and do the increased light justice, projectors |
#10 | |
Lemme show you something!!
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
hid kits range from 100 to 400....FOR 2 LIGHT BULBS.... COME ON I DONT THINK THAT TO CHEAP....ASK ANYONE
too cheap? what are you even talking about? i'm just saying hid's work way better in projectors, rather than stock headlight assemblies
ding-nice work, are you retaining the angel eyes? |
Sierra Grande Club
Thanks for the suggestions. I'm not sure I want to convert to HID tho.
I'm wanting to keep a somewhat classic look, and want something that can a direct fit. Anyone have a link to a source of lamps? I have this Site I used for my Land Cruiser s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 09-30-2008 at 09:09 PM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Daniel Stern's site (which you linked above) is the best I have ever found for lighting information.
Another good site is http://www.rallylights.com/. They also offer headlamp conversions and their prices are competitive. For the money (and results), I would do the relay/wiring upgrade and upgrade to Hellas (item #H50061 at Rallylights). Personally, I prefer the Cibies that Stern offers, but Hellas are also excellent and significantly cheaper.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#15 | |
Sierra Grande Club
I ran Hellas in my 79 Pontiac Sport Coupe back in high school. I was running high wattage low beam and it was bright. I'll look at them again, along with the Cibies you mentioned. s/t
#16 |
![]() Join Date: Jun 2007
I took out the T4's and put in Round Halogen Sealed beams from Autozone. An astounding difference. About 6 or 8 bucks a bulb if I recall.
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. |
#17 |
I have the Hella's and they are great. I have also heard that the Cibies are also excellent. I have a cheapie set of conversion housings in another vehicle and they don't direct the light properly. It just goes everywhere. Get good housings if you are going to use drop in bulbs.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
#18 | |
![]() Join Date: Dec 2006
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
#19 |
Hollister Road Co.
#20 |
Personally I would never consider an aftermarket setup for lights on my truck. What do you do if your whizz-bang headlight goes to he!! while you're on the road? You're screwed. What do you do if a rock kicks up and breaks the light case or whatever you call it? You're screwed.
Do the headlight relay upgrade and go to Wal*Mart or ANY automotive supplier in the US of A and pick up a set of sealed beam halogens. If one goes out ANY place on the planet you're a Wal*Mart or O'Reilleys or NAPA stop away from being back on the road. And you have $100 - $400 extra in your pocket. When did $400 become a cheap upgrade? Call me Rip Van Winkle
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#21 | |
English Chevy Owner
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#22 |
ya thats what i was wondering but up there ^ they saying using hid's is the cheap way.....THATS FUNNY I NEVER NEW 100-400 WAS A CHEAP UPGRADE EITHER.....but ya just carry the 5 dollar normal bulb in your truck....he is right it most likely wont go out but if it does pop the old hid bulb out and pop in the new one....just plugs right in
#23 | |
Tom
#24 | |
If you stick with sealed beams you just stop anyplace on the planet that sells parts and get a new one. Oh and the light from a sealed beam, with the relay upgrade is all you need anyways. If you roll your own relay upgrade your in for $10 worth of relays and less than $10 worth of wire AND you can use the old time religion sealed beams you already have in your truck. Getting a halogen sealed beam if you already don't have them can wait for what you got to get burned out or taken out by a rock. Its a no brainer in my book. Putting in those aftermarket systems is like an art major taking theoretical physics. You can take the class and the grade will count to your GPA but you don't need it.
#25 |
[QUOTE=mrein3;2913195]My point is what do you do if a rock takes out the part you plug your $8 bulb in to? Are you going to find ONE replacement or are you going to have to buy another set. I'm thinking you're stuck buying another set. And the $8 bulb.
If you stick with sealed beams you just stop anyplace on the planet that sells parts and get a new one. Oh and the light from a sealed beam, with the relay upgrade is all you need anyways. If you roll your own relay upgrade your in for $10 worth of relays and less than $10 worth of wire AND you can use the old time religion sealed beams you already have in your truck. Getting a halogen sealed beam if you already don't have them can wait for what you got to get burned out or taken out by a rock. Its a no brainer in my book. Putting in those aftermarket systems is like an art major taking theoretical physics. You can take the class and the grade will count to your GPA but you don't need it.[/QUOTE ....what if a rock falls off a dump truck and trashes your new windshield. ....what if you have a catastrophic failure of a tire and destroy one of your wheels. ....what if your carb inlet cracks, your engine catches fire and your truck burns to the ground. ....what if, what if, what if. Just as you'd never upgrade your headlights....I'd never put rear disc brakes on my truck. They're not necessary. However lot's of people do for many different reasons. This entire board revolves around something we don't need. None of us really needs a classic chevy or gmc truck, but we want them and like them and some of us are inclined to improve them with modern technologies that make them more reliable, safer, faster, cooler, and all around more pleasant to operate. Others are steeped in tradition and want to keep them as close to original as possible. and some don't give a s*#t either way and just drive 'em till the wheels fall off. In essence nothing we do to our trucks, or even our trucks themselves are necessary for the preservation of life, but are vital to some of us for the quality of life we wish to have. Now to answer the question. Here's the order of business I would recommend if you want to upgrade your lighting and retain the stock appearance. 1. Do the relay upgrade. 2. Get some Hella or Cibie H4 housings and bulbs. If this is cost prohibitive, go to your local Autozone and get some Sylvania or Wagner halogen sealed beams. 3. If in time you want to upgrade to HID- you will have to get the housings with a clear lens and faceted refletor to get decent results, or you can get housing that look like a typical sealed beam unit, but actually contain a projector. I think you can get them @ SUVlights.com. Any setup other then factory sealed beam type lamps will most likely require some modification of the core support behind the inside lamps for clearance and accessibility reasons. Good luck!
