10-02-2008, 12:05 AM | #1 |
$550.00 Raised Crossmember Special!
We will be selling the raised crossmember starter kit for $550.00 during the month of October. You can place your orders now if you wish. All you need to do is call us up at 812-782-3581 to place your order. We do not want any money now. Not even a deposit. Once your kit is ready to ship we will call you to finalize all the details. We are expecting to start shipping kits around the 1st of November. We have a few more tests to perform to make sure all is good and ready.
The Starter Kit includes the following.... *Main Crossmember *Upper Bag/Control Arm Mounts *Inner Frame Gussets *Rack & Pinion Frame Notches *Engine Mounting Tabs *Grade 8 Mounting Hardware We are offering this version of the kit for the person who can fabricate, and would like to locate their engine and build their own engine mounts. Its a good kit to get you started. $550.00 [IMG]http://www.*****************/jason/images/c.assbly10.jpg[/IMG] |
10-02-2008, 12:16 AM | #2 |
Re: $550.00 Raised Crossmember Special!
y not just put the engine mounts and be done with it it would sell alot faster being many donbt have time or skill to do it themselves...
10-02-2008, 01:13 AM | #3 |
and were are the engine mounts, i see the mounting tabs....
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
10-02-2008, 01:44 AM | #4 |
Don't you actually want to road test one before you release a "new to you " product? What is the preferd caster and camber #'s for your kit?
10-02-2008, 06:36 AM | #5 |
big guy
ok help me out here, what is the difference from the $700 kit and this one? just welding up the motor mounts? Or am i missing something? Can some one show some pic's of how all this looks on a truck. What are the benefits of a drop member and is it only for guys wanting to lay frame? Thanks Ray
10-02-2008, 11:01 AM | #6 | |
PorterBuilt Man Crush
we will be offering everything listed below during october for $700.00. it will jump to $999.00 after that. we are doing an introductory special. $700.00 gets you...... 1. main crossmember 2. upper bag & control arm mounts 3. inner frame structure brackets 4. rack & pinion frame notches 5. transmission crossmember 6. 350 engine mounts 7. stainless tie rod adjusting sleeves 8. chromoly/teflon 3/4" x 5/8" heims for the spindles 9. all grade 8 mounting hardware $1500.00 gets you...... 1. everything listed above 2. upper and lower control arms 3. upper frame shock mounts 4. monroe shocks
The 72 will live again |
10-02-2008, 09:06 AM | #7 | |
I'm just glad to be here!
X2 What is the ride/handling like? Other products that are available have some road time and feed back as to the ride of the truck after the install.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-02-2008, 11:54 AM | #8 | |
PITbut
Im sure its being tested. |
10-02-2008, 12:10 PM | #9 | |
Keepin it old school
10-03-2008, 12:46 AM | #10 | |
No I saw both of those,what confused me was a company Advertising new suspension parts before they have any possible kinks worked out. I under stand wanting to gauge the market before wanting to put out the money and time to build all the raised members but it just seams back wards to me. I have been around customs and Hot Rods my entire life and have seen this bite company's in the A$$ allot. I hope this does not happen here. This DropMember and raised member is no different than what happened with the MII front ends when they first came out. We used to cut out factory cross members and use them in our rods (told you I've been around awhile) then the first "New cross member" was offered, then they started popping up everywhere you looked. The guys that did their home work and testing and then started selling them are Still out their and the other guys are who knows were now. My main concern is safety we are talking about suspension, steering and brakes lets just make sure it is 100% right before they start being sold. Kevin LFD Inc. Kevin LFD Inc. |
10-03-2008, 06:44 AM | #11 |
big guy
Jasonb72
I am sorry for what i said i thought you were part of SD and i was a little upset on how a company would not take the time to answer all my questions and just show me another add. you were just being helpfull and i am sorry! I really didn't know you were not apart of SD...... sorry again thanks for your help Ray |
10-03-2008, 08:34 AM | #12 | |
10-03-2008, 09:13 AM | #13 | |
Not a big deal, I do appreciate you responding this way.
10-02-2008, 06:03 PM | #15 |
Awesome! The guy thats doing the air ride on my truck (Method Motor Works. Fresno, Ca.) told me he's going to call in tomorrow and order
10-02-2008, 06:34 PM | #16 |
The $700 kit sounds like a better deal then this kit.
The trans x-member, engine mounts, tie rod ends and hiems are worth more then $150. Does this crossmember retain the stock suspension geometry?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
10-02-2008, 07:48 PM | #17 |
Texas Big Wig
Along with the geometry question
I remember reading that the Porter Built Drop Member, has a narrower track width, does this one too ??? |
10-02-2008, 09:21 PM | #18 |
big guy
sorry i was wrong to go after you i didn't know you were not a part of SD
10-02-2008, 09:45 PM | #19 | |
10-02-2008, 09:52 PM | #20 |
Dropmember = Porterbuilt Streetrods
Raised Crossmember = Suicide Doors
10-02-2008, 11:32 PM | #21 | |
Not sure what the problem with my post was, you asked a question I clipped some info you asked for from the other thread and posted for you to see.
I guess I should have taken out the section that made it seem I was with SD. Not sure how that is being an ass. I am not one to get into these pissing contest, just trying to help people get the info they asked for. I have no affiliation with SD. Moderators, I can understand your point of letting the vendors answer their own question, but their are vendors that do not log on and check post for days, and it always seems to be the case that board members and moderators go out find the info from other threads and post it. Maybe the posting rules need to be updated to include this. Quote:
10-03-2008, 08:00 AM | #22 | |
Happy to be here
10-03-2008, 09:14 AM | #23 |
I understand and agree...
10-02-2008, 10:05 PM | #24 |
Another dang good example of why you guys should relax and let the vendors answer the questions on their own product.
I'm trying my best to give you guys friendly advice the nicest way I know how. |
10-02-2008, 10:25 PM | #25 |
