Old 11-20-2002, 04:33 PM   #1
hjalbert
cracker
hjalbert's Avatar
decode frame vin number
number by the steering gear box is 9ba20712
number under cab on the frame is 0t101296 (maybe the zero is an o or something)
any help would be greatly appreciated. thanks
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 11-20-2002, 04:41 PM   #2
Alexis
Member since 2000
Alexis's Avatar
it's the last 5 digits of the VIn number aboive the steering box that match up the the last 5 digits on the VIN number of the truck cab thingy. Don't know about there other though, i also woundered about that too.
Alexis is offline   Reply With Quote
Old 11-20-2002, 09:27 PM   #3
Rod
Neither of the numbers you posted look correct to me. The numbers should be the same. The number under cab is on top of the frame rail... not the number on side of frame rail. It should be the same as the number on top of frame rail near steering box. What's the last 5 on the vin if you know that... all should be the same.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-20-2002, 10:46 PM   #4
hjalbert
cracker
hjalbert's Avatar
unfortunately the cab that is on there is a 69 2wd 3/4 ton, the frame is a 4x4, so the vins wouldnt match anyway, so it just confuses things, any way, that number is on top of the frame rail, and the other one is right by the steering gear box on tope of the frame also, dont know what the deal is, it ias a GMC though, does that make a difference? any way, thanks
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
Old 11-21-2002, 10:20 PM   #5
hjalbert
cracker
hjalbert's Avatar
some ones gotta know something!
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
