Installed pics of SD's Raised Front Crossmember!!
Several of you guys have sent me a pm requesting some install pics of the crossmember kit. These images show the kit at a ride height of 6".
Here is a front view..... [IMG]http://www.*****************/jason/images/68-2.jpg[/IMG] Another front view..... [IMG]http://www.*****************/jason/images/68-4.jpg[/IMG] Overhead shot..... [IMG]http://www.*****************/jason/images/68-5.jpg[/IMG] Another overhead..... [IMG]http://www.*****************/jason/images/68-6.jpg[/IMG] Here is a closer pic of our stainless tie rod connector, and stainless mis-alignment spacers on the chromoly/teflon heim. [IMG]http://www.*****************/jason/images/68-7.jpg[/IMG] A shot of the 1.25" o.d. zq8 swaybar installed..... [IMG]http://www.*****************/jason/images/68-8.jpg[/IMG] Another swaybar pic..... [IMG]http://www.*****************/jason/images/68-9.jpg[/IMG] Lookin down..... [IMG]http://www.*****************/jason/images/68-10.jpg[/IMG] Beautiful!!! [IMG]http://www.*****************/jason/images/68-11.jpg[/IMG] |
Re: Installed pics of SD's Raised Front Crossmember!!
here are a couple pics of our rear kit. we have a few changes to make, but we will talk about the rear later.
[IMG]http://www.*****************/jason/images/68-12.jpg[/IMG] [IMG]http://www.*****************/jason/images/68-1.jpg[/IMG] |
that looks amazing, great work guys, don't mind me as i have to wipe the drool off
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
OG
NICE VERY NICE!!!! HEY JASON YOU NEVER RETURNED MY PM! Whatsup I want to reserve my cross member let me know!
#5 | |
im leaving right now to go out of the country for 10 days. if anyone has a question shoot me over a pm. im not sure ill have internet access, but ill have my laptop with me. hopefully i return with one hell of a tan. if anyone wants the $700.00 or $1500.00 october special just give us a call to reserve one. no money or deposit is required. we will call you when its ready. $700.00 gets you...... 1. main crossmember 2. upper bag & control arm mounts 3. inner frame structure brackets 4. rack & pinion frame notches 5. transmission crossmember 6. 350 engine mounts 7. stainless tie rod adjusting sleeves 8. chromoly/teflon 3/4" x 5/8" heims for the spindles with stainless misalignment spacers 9. all grade 8 mounting hardware 10. upper frame shock mounts $1500.00 gets you...... 1. everything listed above 2. upper and lower control arms 3. monroe shocks |
sweet!!! what kind of rack and pinion dose it use, and when is the rear kit available. will it lay frame?
1967 LWB 4speed-current project ![]() 1970 LWB 3 speed -stolen ![]() 1980 Z28 - sold 1968 Barracuda Big block- sold ![]() 1969 Firebird 400/400-sold |
here is a pic of the swaybar at its lowest point when laying frame. 1.25" off the ground. its about even with the lowest part of the crossmember.
[IMG]http://www.*****************/jason/images/68-13.jpg[/IMG] |
sorry missed that, thanks. enjoy your vacation
ok where is it laying frame is there a pic of that !!!!!!!
nickle and dime |
nice
any updates on this its past mid november
nickle and dime |
#15 |
nickle and dime |
#16 |
that's low enough for me thanks. how bout that rack and rear kit?
#17 |
OG
Thanks for the reply! I cant wait to get my drop on! Man that frame looks sweet, too bad I already started my back half setup with 4link I would have waited to get the SSD back half too. DAM!
#18 |
Texas Big Wig
Its hard to tell in the pics, but it looks as if the bag is awfully compressed at ride height
From the ride height of 6" how much extra lift does it have & when at dump how much camber is there ??? also, is it riding at that height & laying frame with 3" drop spindles or what ??? Is the track width narrowed any ??? |
#19 |
African-American Shaolin Monk
I think the bags look compressed because there is no air in them the frame is sitting on, what looks to be 6 inch blocks for explanation purposes. (ie: these pics to give you and idea of where it sits) How about a side shot ?
#20 |
1.) Will the tubular arms work with stock crossmembers? Or only the raised crossmember?
2.) What year ball joints are required? Thanks, Shane |
#21 | |
1.)The arms will work with a factory x-member 2.)The ball joint press dia. is the same for all years of this arm. Last edited by Shane; 10-04-2008 at 05:36 PM. Reason: my mistake - going for QUOTE button - hit EDIT - nothing changed |
#22 |
#23 |
Keepin it old school
When I called Suicide Doors the guy on the phone said that when you place the order for the kit they ask the customer some questions about there truck. One questions being if they will be using stock or tubular control arms..
Is there changes made to the crossmember to use the stock arms? I was wondering if someone orders a crossmember to be used with stock control arms can they easily switch to tubular control arms at a later date?? Thanks.. |
#24 | |
The X-member is the same ether way. Also on some stock arms you will need to trim some for rack clearance in the X-shaft area on one side. |
#25 |
Does the SD crossmember move the wheel forward to center it in the wheel opening? or does it leave the wheel in the stock location?
