10-06-2008, 08:15 PM | #1 |
Do I need this pink wire on the solenoid?
I think I already know the answer to this, and is probably a dumb question but...
I converted over to HEI today and instead of running a new 12 gauge wire, I used the one off of the carb solenoid.. what does that solenoid do? I am going to hook it back up, but it sure seemed to run just fine without it.
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 ) 2001.5 VW Passat beater 1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint |
10-07-2008, 09:14 AM | #2 |
Re: Do I need this pink wire on the solenoid?
I would suggest not using the wire to the solenoid as it is probably part of an emissions system. The supporting wiring and relays are not designed to carry an HEI distributor.
A 12 gage wire to supply a full 12 volts to the HEI distributor is a much better way to go. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-07-2008, 09:53 AM | #3 |
Thanks for the reply but it is a 12 gauge wire that is plugegd directly into the "unfused ignition" post on the fuse box.
regardless, I am going to tap off of it and reconnect it. I need to tap off of it because there is only one terminal in the fuse block for switched ignition.
10-07-2008, 03:08 PM | #4 |
10-07-2008, 03:20 PM | #5 | |
because it's in the FAQ like that
10-07-2008, 03:28 PM | #6 |
10-07-2008, 04:12 PM | #7 |
I am a Referee of life.
Read the FAQ by "shifty" it's very detailed(even gives the part # for the terminal) and it will show the way to replace the resistor wire and make it look factory.It's for a 6 but the same for any 12 volt.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
