Old 10-07-2008, 12:25 AM   #1
Pyrotechnic
Pyrotechnic's Avatar
Power steering squeal
When ever I turn the wheels all the way to the locks on either side, I get a loud squealing sound. Doesn't sound like the belt is slipping. What can I do to stop this ? Sometimes I forget to turn the wheel slower as I get closer to the locks, and it's kind of embarrassing to have your vehicle making odd noises.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 10-07-2008, 12:45 AM   #2
78chevstepside
78chevstepside's Avatar
Re: Power steering squeal
mine does the same thing. wd-40 cured that problem.
78chevstepside is offline   Reply With Quote
Old 10-07-2008, 06:25 AM   #3
Albatrossian
Georgia Boy
Albatrossian's Avatar
I had the same problem.. put a new belt on, still did it.. found out that both belts, old and new, were sitting too low in the pulleys.. and that was causing the squeal. Check it out.
Albatrossian is offline   Reply With Quote
Old 10-07-2008, 10:46 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
yeah its definately the belt slipping causing the squeal
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-09-2008, 02:29 PM   #5
Pyrotechnic
I've done more searching and about the best thing and I found several things. I have a brand new belt and brand new Alan Grove brackets which are extremely sturdy, more so than stock brackets.
One was that "the air was not fully bleed out of the pump and that could cause it to squeal when turned against the locks."
Another was that "these older pumps don't have high pressure relief valves. Newer pumps do because people insisted on turning the steering wheel hard against locks which tends to burn up the older style pumps."
What is the correct answer ? I still know. I'm going to read through my 77 GMC manual and see if it contains any info on this.
I'm just really surprised there is not more info about this. Everyone acknowledges that there is in fact a squeal when turning against the locks. Every power steering pump I've had of this design does it, BUT, I still do not know if these trucks did this right off the show room floor, or if there is a solution to the problem.
Old 10-09-2008, 02:30 PM   #6
COMP
all mine do it ,,its the pump going full pressure at lock
COMP is offline   Reply With Quote
