10-07-2008, 02:49 PM | #1 |
Gen III guys: power steering and radiator hoses
You guys that swapped in gen 3 engines into your trucks, what did you do for radiator hoses and power steering hoses?
I'm running corvette accessories, so mine may be a little different than the truck or f-body accesories, but some help will get me started. I camaro radiator hoses, and they're too small of diameter and too short to fit. I know I can make them fit, but wanted to see how some of you all overcame these issues. Thanks |
10-07-2008, 05:09 PM | #2 |
Re: Gen III guys: power steering and radiator hoses
on the PS hoses you'll be forced to make them, either by getting AN fitting and verios adaptors, or haveing a A/C hose repair shop make it for ya..(most do PS hoses too) ....as far as the rad hoses i assume you need the upper....what ive heard alot of people do is bend a clothes hanger to the shape and rummage through the parts store..
10-07-2008, 06:32 PM | #3 |
The clothes hangar method works really well, I've done it countless times and usually end up happy. I end up coming home with 4-5 ones that I think are close, then return the ones I didn't use.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
10-07-2008, 08:22 PM | #4 |
I used the factory rad hoses, but I have a truck motor. On the PS, the return side is easy. But on the pressure, I used the factory 5.3 hose, cut it off, then crimped on a gates hydraulic fitting that screws into the steering box. I believe the part number is G25504-0607. Works great.
10-07-2008, 09:54 PM | #5 | |
10-07-2008, 10:45 PM | #6 |
The return side is just a hose held on with hose clamps. Cut to the appropriate length and attach....easy.
10-08-2008, 09:47 PM | #7 |
Questionable
i answered your PM on LS1 tech: Use the stock 68-72 low pressure power line - it just hose-clamps to the low pressure side of the pump resevoir.
For the high pressure side, get a high pressure F-body line, and a high pressure 68-72 truck line, measure for approximate length and have a hydraulic shop merge the two halves you need. As for the radiator hoses, I just got the stainless steel bendy ones, I bought them at a cheapy shop online rather than paying a fortune for namebrand, didn't want to be using rubber hoses, too much of a pain.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-24-2008, 02:05 AM | #8 | |
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
10-09-2008, 12:26 PM | #9 |
Maybe a stupid question, which port on the power steering gear box is the high pressure supply, and which one is the return?
10-09-2008, 06:53 PM | #10 |
Pretty sure the bigger one is pressure, but it's been a few months since I've looked.
The fitting costs about $12. |
10-11-2008, 12:05 AM | #11 |
I screwed the stock steering line right into the reservoir on the 6.0L. Not sure if they are actually the same thread or not but it went in smooth and has never leaked. Just my .02
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
10-11-2008, 08:20 AM | #12 |
yep I did what I think boost said I rmoved the fittings from the pump on my stock one and the 5.3 one and swapped them then just used my factory (stock) one from my truck
worked great 15,000 miles later no problems
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
