10-07-2008, 08:16 PM | #1 |
help
im new to engines, and i am trying to replace the original timing gears on my 74 350, i pulled the gear attatched to the cam and the chain no problem, but i cant get the crank gear off, i tried the only pronged puller i have to pull the old gear off the crank and it moved a little then my puller busted,
there has to be a better way to pul this gear off thanks nate
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
10-07-2008, 08:43 PM | #2 |
Re: help
i've had luck taking a rubber headed striking mallet and tapping it back towards the motor then see if the key way will come out. if not then find a bigger gear puller.
10-07-2008, 09:27 PM | #3 |
Re: help
the keyways i have seen before have been one peice, the keys on my crank are seperate and when i removed the harmonic balancer the first key did not fall off, is that normal?
thanks nate
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) Last edited by drivethechevy; 10-07-2008 at 09:28 PM. Reason: spelling |
10-07-2008, 09:56 PM | #4 |
Re: help
thats normal but you will probably want to remove the harmonic ballancer key before removing the gear , to be on the safe side.
10-07-2008, 11:04 PM | #5 |
Re: help
whats the best way to go about removing the keys?
thanks nate
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) Last edited by drivethechevy; 10-07-2008 at 11:04 PM. Reason: spelling |
10-07-2008, 11:35 PM | #6 |
Gone Fishing
Re: help
I have used a 3 jaw puller to remove the crank gear before
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
10-08-2008, 07:24 AM | #7 |
Re: help
Some will not agree with this, but since you are not going to use that crank gear anyone, take a steel chisel, and hit between the teeth of that gear a couple times. That cast gear will break right off. Just make sure to put a rag behind that gear to prevent anything from going into the pan. I've been doing it that way for years.
1997 GMC Sierra Ext 1965 Mustang |
10-08-2008, 07:36 AM | #8 |
Re: help
if its not woren real bad i just leave it i've never had any problems
