Old 10-08-2008, 05:38 PM   #1
lks dcvn
lks dcvn's Avatar
Cleaning out my stash - a LOT for sale (Vintage Air, 700r4, etc) - Toledo, Ohio
I have a bunch of stuff that I would like to sell - all items are located in Toledo, Ohio.
Vintage Air (Sure Fit) Evaporator Kit - just bought this from a board member about a month ago - #75067-LCZ-A - in the same box I got it in - http://www.vintageair.com/cat2007/51.pdf - $475+shipping (SOLD)
700r4 from a 87 Camaro - was told it was ready to go - have not tested it since I bought it (6 mos ago) - no way to know for sure - figure it for a core - $120 - picked up in Toledo
A/C parts for the firewall, and interior plastic components - no duct work - $150 obo
72 Front suspension and disk components - UCA, LCA, spindles, rotors, etc. $100 obo
72 Rear Axle - with roller tires on it - 3.08 gears (non posi) $100 obo (Pending)
Buy the two above for $160
Blazer Utility Buckets - $175 obo - will need recovered
71-72 OE (non SS) Fine Lines set of SBC, 2WD TH400/TH350 Trans Cooling Lines - NIB - $30 + shipping
Blazer Swing Away Tire Carrier (with hardware) - $200 obo
67 Front Quarter Panels - from TX - in epoxy primer - small bit of fiberglass in the bottom of one of them - cannot tell on outside - $200 for both obo
68 Rear LWB Bedside - will have to check on which side it is) - good condition - $60 obo sold
68 Bed Wheel Tub - decent condition - $50 obo
LWB Bed - solid bedsides - but floor has holes in it - could be great for hauling wood or scrap - no tailgate - $70 obo
1967 LWB Truck - no motor/trans - basically a cab (rusty on the bottom), frame (straight and solid), bed (wood floor) and a tailgate (not great condition - but it works) - interior has been stripped - but it can go with for some extra $ - I do have a clear MI title for this one. Newer tires and rims. $500 obo - you can sell parts (core support/grill/tires/tims/etc.) off this and recoup your costs.
1972 Rolling Chassis - from TX - surface rust only - straight. Trailing Arm frame with 5 lug rollers on it. If you buy this I will throw the LWB (bed) mentioned above on this for you for free and include it in the price - $150 obo (Pending)
Larger stuff will need to be picked up in Toledo, Ohio. Pix will be coming soon.
PM me with your questions/concerns (or if my prices are way off).
Thanks for your time.
Edited for clarification of the bed being what I would throw in for free - not the LWB truck -
lks dcvn is offline   Reply With Quote
Old 10-08-2008, 06:09 PM   #2
lks dcvn
lks dcvn's Avatar
Re: Cleaning out my stash - a LOT for sale (Vintage Air, 700r4, etc) - Toledo, Ohio
pix 1
Old 10-08-2008, 06:10 PM   #3
lks dcvn
lks dcvn's Avatar
pix 2
Old 10-08-2008, 06:11 PM   #4
lks dcvn
lks dcvn's Avatar
pix 3
Old 10-08-2008, 06:12 PM   #5
lks dcvn
lks dcvn's Avatar
pix 4
Old 10-08-2008, 06:13 PM   #6
lks dcvn
lks dcvn's Avatar
pix 5
Old 10-08-2008, 07:36 PM   #7
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Is the Vintage air a complete kit ready to install. If not what is it missing. I know a guy here in town that is looking for one.
Thanks PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 10-08-2008, 07:48 PM   #8
lks dcvn
lks dcvn's Avatar
Complete Evaporator Kit - no parts missing - I checked the inventory list when I got it from another member...
The part number is 75067-LCZ-A and it is described as:
EVAPORATOR KIT: Air conditioning, heating and defrost combination designed specifically for your vehicle. Original deluxe control assembly in your dash connects to and controls this unit. Designed to mount to existing holes in your dash and firewall without drilling* or fabrication. Evaporator kit comes complete with all mounting brackets, hardware, louvers, duct hose, wiring harness and installation instructions.
This is not the complete kit - but if you have the under hood stuff (condenser and drier) - you should be ready to go...
Old 10-08-2008, 07:39 PM   #9
jorgensensc
jorgensensc's Avatar
Is this the same vintage air kit that I was in line for last month? If so I will take it!! I need it for the wifes burb. Let me know. I can paypal the money. PT, I'm not trying to jump in front of you. I was trying to get it last time. I will of course be after you.
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-08-2008, 07:55 PM   #10
jd774430gf61
call me i ll take the cab if is good 1-517-543-8691
jd774430gf61 is offline   Reply With Quote
Old 10-08-2008, 08:12 PM   #11
PT'S 70 CST
"GO DAWGS"
So if your truck is a non factory air truck you will still need some stuff to insatll it. Also do you know if it will fit on a factory big block or is there anything different that you would need other than the pulleys and brackets.
PT
70 CST SWB
70 NOVA
2000 Silverado swb
29006
Old 10-08-2008, 08:28 PM   #12
jorgensensc
PT,
I know I'm shooting myself in the foot, but yes you would still need a compressor, condensor, and dryer. It will work for a big block also, you will need the pulleys and brackets also. you will need to buy the A.C. controls also if your truck didn't come with A.C. Hope that helps a little. (Although secretly I hope your freind doesn't want it )
Shawn
Old 10-08-2008, 11:31 PM   #13
PT'S 70 CST
"GO DAWGS"
Thanks Shawn, its your lucky day. I called my friend and he has a 68 and does not have any A/C stuff and is going to try and buy a complete system. So I am going to pass it on to you.
PT
70 CST SWB
70 NOVA
2000 Silverado swb
29006
Old 10-08-2008, 11:53 PM   #14
finch
finch's Avatar
oh man, any idea on how you could ship the rearend?
Andy...
'70 C/10 Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=298553
'71 K/20 Frame-off resto, SOLD!!!
http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12
'05 Silverado Z-71, CC SB, Daily Driver
finch is offline   Reply With Quote
Old 10-09-2008, 10:45 AM   #15
finch
finch's Avatar
Andy...
Old 10-09-2008, 12:09 PM   #16
budman k20
1972 K20
Hi,
Please put me next in line if the Vintage air stuff does not sell.
budman k20 is offline   Reply With Quote
Old 10-09-2008, 01:44 PM   #17
lks dcvn
lks dcvn's Avatar
jorgensensc - I will take it tomorrow to check pricing - USPS online says $35 (using my guesstimate numbers) - but want to give you an exact price.
No idea on how to ship the rear - if you know anybody coming through - you are welcome to have them pick it up and bring it your way...
Old 10-09-2008, 02:20 AM   #18
MDC
MDC's Avatar
wish you were closer. I need that tranny and disc brake stuff
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
Old 10-09-2008, 04:44 AM   #19
tommypic
tommypic's Avatar
me hopes jorgensensc dont take either . I will take The Vintage air per post 10
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 10-09-2008, 08:50 AM   #20
lks dcvn
lks dcvn's Avatar
jorgensensc - you are up on the vintage air - what is your zip and I can get you a shipping quote.
I am guessing around $30 but want to be sure...
Old 10-09-2008, 09:23 AM   #21
jorgensensc
lks dcvn,
My zip is 77018. I can paypal the money when you give me the total. Thanks for sending this deal back out to us.
Pt, Thanks for finding out about your friend so quickly!! I really appreciate it!
Tommy, Sorry man, but the wife will not let me miss this one again!! She wants A.C. in her burb so she can start driving it!!! Good Luck to you!!!
Ahh. I guess good karma came back around for us!!! Awesome.
SHawn
Old 10-09-2008, 02:11 PM   #22
NWD02
Please put me in line for the vintage air.
Thanks.
NWD02 is offline   Reply With Quote
Old 10-09-2008, 07:08 PM   #23
jorgensensc
lks dcvn,
Two questions really quick. First, in the description it says it connects using your deluxe controls. I have been assuming that meant the A.C. Controls. That is correct right? This system doesn't use the heater controls does it? Second, if you will send me your paypal addy I can just paypal you the total with 35.00 for shipping. Then if is right you can mail it off without making a second trip. If it is more for shipping I can send you the difference. If it is less, you keep the difference. How does that sound? Would that work for you? Please add insurance to cover the cost of replacement if damaged (approx 650). If it increases the shipping I will pay the difference. Let me know.
Shawn
Shawn
Shawn
Old 10-10-2008, 02:30 PM   #24
STINEY
STINEY's Avatar
Don't toss these yet, I'm interested in some or all of it. I'm in Bucyrus Ohio.
Was the 72 chassis a LWB C-10? 5-lug all the way around?
How rusty is the '67 cab? Vague question I know, but still....
STINEY is offline   Reply With Quote
Old 10-10-2008, 02:57 PM   #25
lks dcvn
lks dcvn's Avatar
Was the 72 chassis a LWB C-10? 5-lug all the way around? Yes on both counts LWB and it has 5 lug rollers on it now that don't hold air well - but I could pump them up to get it rolling around again.
Rusty near the bottom -
floor - patched with sheet metal and rivets by PO - only on edge - center of cab is pretty solid
rockers - created with sheet metal and riveted in - not too bad a job actually
inner rockers - gone
cab supports - there somewhat - obviously rusting away - and need serious work
corners - I can't remember - but can check if you are interested
Short answer - could it be used today - no, could it be easily saved if you have a knowledge of welding - yes.
STINEY If you take all that stuff - I will give you a bulk discount on these items...let me know. I can get pix of whatever you would like to help your decision one way or another.
PM me for details if you want.
