Old 10-09-2008, 11:16 PM   #1
70stroker
70stroker's Avatar
Smile no more
no more in cab gas tank..... actually i had my fuel cell in my bed for about a year now but just now got the courage up to weld some metal in and take the tank out.
first time welding and body work. the pics looks like its got a dent or something right above where the filler use to be but its smooth just a glare from the flash.
70stroker is offline   Reply With Quote
Old 10-09-2008, 11:31 PM   #2
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: no more
Well done "Stroker"! I'd be interested in seeing the fuel cell you're running. I want to ditch the stock in-cab tank but can't decide which method to use. Blazer tanks are cheap-ish, but hang down a bit too much for my liking. Poly cells are also inexpensive, but plastic.......I dunno. Then there's the aluminum and stainless tanks- da' bomb fershizzle, but hella pricey too! Can you tell I'm severely undecided.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 10-09-2008, 11:54 PM   #3
70stroker
70stroker's Avatar
Re: no more
thanks i was really nervous...i think it turned out good tho..
theres some pics of my fuel cell in my build thread, im making mine mostly street strip so i just mounted it in bed.
http://67-72chevytrucks.com/vboard/s...d.php?t=309919
Old 10-10-2008, 12:03 AM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: no more
That looks good, did you just take a piece of sheet metal and bang it to fit the rough shape of the hole and bondo it up??
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-10-2008, 12:06 AM   #5
70stroker
70stroker's Avatar
Re: no more
no i took a 5x 5 inch piece of sheet metal and held it up and took a sharpy marker and traced from the back side. then i cut and grinded the piece of metal the the hole shape with the little notch on the bottom, then i tacked it in in one spot and shaped it with the cab as i went. theres really less then 1/8 inch of mudd at the deepest place on it.
