Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 10-10-2008, 08:10 AM   #1
clos69
Its Topless Season!!!!
clos69's Avatar
WIW- 1986 Corvette TPI
A friend wants to sell me an 86 (L98) TPI w/computer... it has 180k miles on it. Can some one tell me what this is worth....is $250 to much.?
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 10-10-2008, 09:34 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: WIW- 1986 Corvette TPI
IDK what its worth, but pictures always help
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-10-2008, 09:43 AM   #3
David Johnson
David Johnson's Avatar
The tuned port manifold, plenum and runners are worth more than that. Then it should be and aluminum headed 4 bolt block if its from a vette and not a camaro or something. Definately worth it!
David Johnson is offline   Reply With Quote
Old 10-10-2008, 03:19 PM   #4
Ackattack
Ackattack's Avatar
yeah, I'd say that's a fair deal, I believe the 87+ have roller cams, but still a fuel injected 350 for 250 bones ain't bad.
Ackattack is offline   Reply With Quote
Old 10-11-2008, 07:12 PM   #5
streetstar
streetstar's Avatar
I can't tell from your post whether it is the complete engine, or just the fuelie setup --- either way, its a good deal --- if its the complete engine with AL heads, its a borderline steal.
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 10-12-2008, 09:31 PM   #6
earl87gta
earl87gta's Avatar
thats a great deal the reason why is that the vet base plate or intake has the old style head bolt patern the injectors are also biger 21lbs instead of 18lbs. other then that its all the same. The EGR is alittle difrent too but nothing your going to use any way just find some one from one of the vet or f-bodt boards that has tuner cat and every thing to burn you a chip and have one made with the egr stuff turned off.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-14-2008, 09:34 AM   #7
clos69
clos69's Avatar
Thanks for the replies guys....he is asking $250 for the complete TPI or will take $400 for the complete engine. I think I am going to go ahead and buy the whole thing...what do ya'll think...how hard is it to install this?
-Carlos-
The of America
Old 10-14-2008, 10:27 AM   #8
earl87gta
earl87gta's Avatar
400 for the hole engine is a steal you can get 400 for the heads by them selves the engine is no diffrent then any other 350 would be for you. The wiring is a paine in the but so if I was you I would just buy a painless wriing harness if you dont feel like chacing the wiring down. there is a place that will convert the vet harnes to 3 wire hook up but it isnt that much cheaper then gettting a painless harness. the big pain with that TPI system is its a mass air system so you have to worry about air intake a little more do to the mass air sensor. again this is an easy fix if you go to a painless system and go to a speed dencity set up. you can also convert the mas air to speed dencityeasly on the origanl harness. . to do this you will need an ECM out of a camaro or fire bird.. If I was you I would spend some time thirdgen.org they have years worth of info on TPI convertions and sevral guides on how its done.
Earl
Old 10-22-2008, 06:19 PM   #9
70rs/ss
70rs/ss's Avatar
I'd do it the Vette heads are a decent aluminum head and the block is roller cammed, make one heck of a 383!
70rs/ss is offline   Reply With Quote
