10-11-2008, 11:12 AM | #1 |
Best Parts to look for?
If I wanted to add disc brakes and power steering and all the good stuff to a 1960 Sub, what would be the best parts truck to look for? There is a 1985 1/2 suburban for sale locally and I was just curious if I could pirate a lot of the parts. What years work best?
10-11-2008, 12:40 PM | #2 | |
Re: Best Parts to look for?
10-11-2008, 02:09 PM | #3 |
p/u's 71-89 and suburbans to 91 will all work. if the 85 is cheap enough go for it or as the other poster says look around for a beater one sitting somewhere
rom |
10-11-2008, 02:53 PM | #4 |
Well they only want 500 for it, and it supposedly runs and drives good with a new transmission. I was thinking of using the motor and trans and seats and everything, so I think it would be worth it. If I switched to the newer front suspension, if i wanted to buy drop springs or spindles for it would I just get them for an 85 suburban?
10-11-2008, 03:41 PM | #5 |
offer them 300(the worst that they can say to you is no) and see where it takes you . you might get it for 400.They also may tell you to take a hike, but you'll be doing them a favor by getting rid of it for them
you would order 85; yes ron |
10-11-2008, 03:56 PM | #6 |
Alright thanks guys. Are there any avoidable problems or anything involved with changing out the suspension?
10-11-2008, 04:09 PM | #7 |
Resistance is Futile
No, but its UNavoidable that your wallet will look like it got hit by a bus!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
10-13-2008, 08:49 PM | #8 |
Where could I find info on his kit
10-14-2008, 02:05 PM | #9 |
10-19-2008, 09:30 AM | #10 |
This is what it looks like. http://www.classicparts.com/1960-66-...ctinfo/76-979/ It dosen't look like much, but it really lines up the steering box for you. Before I knew about it. I drilled my own holes in the frame and I was off a bit. When I put the kit on it raised the box up by the shaft 1/2" and I had to redrill the idler arm again. I can say that my truck did turn more to the left then the right and now it seems like it will be ok, but I wont know untill I drive it again. I did change the steering box also.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 10-19-2008 at 09:32 AM. |
10-19-2008, 07:54 AM | #11 |
Hey is your Burb auto? If it's NOT then you probally have a HYD clutch. This will make this project a little more difficult but not impossible. If you need some details on HYD clutch Hit me up. I won't ramble here until you let me know.
The Gist is, if you have hyd clutch you'll either have to put in a hyd clutch master cylinder or convert to manual clutch or go with an Auto trans.... Last edited by soba_03; 10-19-2008 at 08:01 AM. Reason: pic's |
